Old 10-22-2003, 03:48 AM   #1
68 Suburban
68 Suburban's Avatar
Question Lower Radiator Hose on a Small Block Question?
My lower radiator hose rides on the frame where is curves up a little. This has left a groove in my past two hoses. Is the correct set up?
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 10-22-2003, 04:17 AM   #2
gold68shortstep
you must have the wrong radiator. does the botom "spickit" curve upward? if not you have the wrong radiator and that is the problem. i've been driving a 71 for the past 6yrs and have to replace mine once every year for the same reason. i have a 78-87 G body 3 core rad in mine and it has a straight "spickit" hose rubs on the upward curve on the frame. the correct radiator for a 67-72 GM truck has a lower "spicket" that curves upward to clear the frame. you need the right radiator for your truck.
gold68shortstep is offline   Reply With Quote
Old 10-22-2003, 04:36 AM   #3
Lippyp
English Chevy Owner
Lippyp's Avatar
Mine has a piece of old tyre inner tube wrapped around it where it rubs and it seems to stop any problems. Not hugely pretty but unless you've got a show truck....
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 10-22-2003, 04:39 AM   #4
68 Suburban
Thanks for the replys. My last hose was at least 3 years old with out any problems, but I don't want to push my luck... :p
Old 10-22-2003, 07:29 AM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Get yourself a piece of fuel hose a couple of inches long. Split it lengthways and slip it onto the edge of the frame where it rubs. That's what I always do.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 10-22-2003, 07:32 AM   #6
mrein3
mrein3's Avatar
Lippyp and Tx Firefighter have it down. I use a piece of discarded heater hose about 4 inches long, split length wise. The heater hose is held on the frame by the radiator hose. The "hose on hose" contact doesn't ruin the radiator hose.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 10-22-2003, 07:37 AM   #7
Ed ke6bnl
Or on the other end take some of the old hose and cut to about 4 in and slit and cover the hose where it rubs. Ed ke6bnl
Ed ke6bnl
Agua Dulce
70 S.E. Los Angeles
70 Chevy short bed
1948 F3 ford pu
1949 F1 stock V8 flathead 3 on floor
1950 F1 pu street rod
1948 F6 Ford Dually/350sbc no bed stock trans&rear
1972 El Camino 4" chop
1953 Chevy 3100 2b daily driver
1970 SB 4X4 400ci 6in lift
Ed ke6bnl is offline   Reply With Quote
Old 10-22-2003, 07:38 AM   #8
68 Suburban
Was this a poor design from the factory?
I wish I had save that lower radiator hose I replaced Then I would have the piece I need...lol. I guess I will have to spend $7 for a new one to make the piece.
Old 10-22-2003, 07:50 AM   #9
tom hand
CCRider
tom hand's Avatar
If you do have a radiator that has a bottom straight "spickit" just use a 73 up chevy truck hose....works perfect
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 10-22-2003, 11:13 PM   #10
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Mine rubs, and I did the scrap hose section deal too.
When i had the rad guys at work fixin me up a rad for the one ton, I had them move the water outlet up an inch. Don't know if it'll help or not, but it is a vain attempt at re-enginearing GM's mistake.
