#1 | ||
Moderator
![]() Join Date: Oct 2008
Re: temp gauge not working
The original temp sender is screwed into a hole in the Left Hand cylinder head that's inline with the spark plugs. You prolly have a plug where the sender is supposed to screw in. Using a sender in the intake is problematic because the intake is the high point in the cooling system. If all is well it should read the coolant temp just fine. However. If you develop a coolant leak the sender will be reading an air pocket temp and not the temp of your overheating engine. The stock temp sender for the earlier builds of these trucks is 1/2-14 NPT. If you have early stock heads the Standard Motor Products TS6 is the right sender. Popular later model heads, like the Vortec, use a 3/8-18 NPT sender. The 3/8-18 NPT senders started to be used in 1986, or a little before, so the Standard Motor Products TS76 or an equivalent should work. You need to be careful to stay with the 1980's 3/8-18 NPT senders. The stock sender ohms out 13KΏ-34KΏ Cold and 60Ώ Hot. Some later senders, but not all, are the opposite... low Ώ cold and high Ώ hot. Take a meter with you to the parts store and check the Ohmage on the new sender. If the new sender is 13KΏ to 34KΏ cold it'll probably work.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 11-25-2012 at 02:37 PM. |
78K & 79C Jimmys
I had to use an adapter to fit the smaller sender into the larger hole
this is both the oil and temp I used ..... TS76 - temp
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
