Old 11-22-2012, 02:09 PM   #1
1269lg
4" lift?
I have a 1966 GMC 3/4 ton 2wd with coiled springs in front. I wanted to know what the easiest and cheapest way to lift the front 4". Thanks for any help.
1269lg is offline   Reply With Quote
Old 11-22-2012, 02:37 PM   #2
Redcap
Re: 4" lift?
Get a 4x4 frame?
Redcap is offline   Reply With Quote
Old 11-22-2012, 02:45 PM   #3
1269lg
Re: 4" lift?
I was hoping to lift it some how without getting a 4x4 frame.
Old 11-22-2012, 02:52 PM   #4
Redcap
Re: 4" lift?
Making a pre-runner truck?
Old 11-22-2012, 03:03 PM   #5
1269lg
Re: 4" lift?
I"m trying to level the truck. so maybe 4" is to much maybe 2" is better. I was just wondering if taller coil springs were available. I want the stock 4x4 look without having to do the conversion. I'm kinda green at this stuff.
Old 11-22-2012, 06:49 PM   #6
84 400
Sb 400 club
84 400's Avatar
Re: 4" lift?
Find some one who makes coils in your area. Had a guy near me make some for a 98 amigo for 2 inches of rear lift. Ran me $200. Also keep in mind you will need longer shocks, brake lines and steering may need attention.
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 11-23-2012, 12:24 AM   #7
Mike C
Mike C's Avatar
Re: 4" lift?
JC Whitney I think still has lift coils for older trucks would be another option.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 11-23-2012, 02:12 AM   #8
argonaut
argonaut's Avatar
Re: 4" lift?
I think you may find that if you put a longer, "lift" coil spring up front that the upper control arm will be nearly sitting on top of, and maybe touching, the upper coil bucket on the 2wd crossmember. There won't be any room to install the rubber bump stop. You will have very little droop and when going over a big bump the UCA will hit the upper coil bucket, making an unpleasant slamming sound.
I installed 3/4 tons HD springs in my 64 1/2 ton chevy shortbed pickup (the HD have a larger diameter coil and a higher spring rate) to get as much lift as possible front and back. This didn't even come close to leveling the truck out, and I feel that my front suspension is just about maxed out. It simply wasn't designed to operate at that geometry. I think you'd have to do what the later model chevy truck guys do and make some custom spacers to drop the entire front crossmember down, relative to the frame.
I'm not trying to be a downer, but I think that is the reality of the situation. What kind of springs do you have in the rear of the truck?
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 11-25-2012, 12:07 PM   #9
dbmx66
Re: 4" lift?
i guess it really depends how much time and $ tyou wanna put into it.
dbmx66 is offline   Reply With Quote
