Old 11-24-2012, 09:42 PM   #1
mlevario99
Exclamation 5.3 into a 66 c10 - engine does not start
I am trying to start a 5.3 engine that I isntalled in a 66 truck. I have not reprogramed the computer but I do have HP Tuners to do that. Well just now I try it and it crank but it does not start, like there is no spark. The fuel pressure is fine , I tested with a gauge. I remove the spark plug wire and put the tip of a screwdriver and crank it and there is no spark from the screw driver. Do you guy have any ideas what could it be. I check the grounds and I think I have them all. I check the pink wires and they have power.
Any ideas.
mlevario99 is offline   Reply With Quote
Old 11-24-2012, 09:50 PM   #2
71chevystep4x4
71chevystep4x4's Avatar
Re: 5.3 into a 66 c10 - engine does not start
I would immagine that it is because you have not reprogramed the computer yet. I was under the impression that they will not start until the VATS have been dissabled.
71chevystep4x4 is offline   Reply With Quote
Old 11-24-2012, 09:53 PM   #3
mlevario99
Thanks 71chevystep, from what I have read before, the engine is supposed to start for a few seconds and then it dies, but I could be wrong, I guess I need to disactivate the VATS and try it again, and see what happens
Old 11-24-2012, 11:03 PM   #4
mlevario99
When I was working on the harness I had to replace the crank position sensor plug, I bought it at the GM dealer, but the wires the fron the plug were all white, now I am wondering if they have a particular order they need to go
Old 11-25-2012, 01:06 AM   #5
bk2life
not a few seconds, about one tenth of a second.
bk2life is offline   Reply With Quote
Old 11-25-2012, 03:08 AM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
unless all of your coils are also dead, its probably VATS as mentioned...
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 11-25-2012, 11:12 AM   #7
mlevario99
I check one set of coils in another engine and they do work. I dissable the VATS last night. What else could it be, can the crankshaft position sensor plug be wired incorrectly. Any ideas
Old 11-25-2012, 05:31 PM   #8
mlevario99
Well I wired the crankshaft position sensor wrong, I rewired and it work for a while...
I bought a module from current performance wiring with all the wires
And relays for the harness, and it was working fine but then
Something happen and is not workin anymore, the relay that opens the
Power for the other fuses is not working, I have power but it
Just doesn't open the circuit.. Also the starter relay when you
Crank the switch and I use a test light the light turn on green
Instead of red, any ideas
