Old 11-24-2012, 11:03 PM   #1
bdrew67
bdrew67's Avatar
any ideas
I purchased a 1967 chevy short bed a couple months ago, and decided to start tear down yesterday. After taking the front end off I noticed someone has cut the frame. I have no idea why. I thought the frame had been bent, but i checked the measurements and the frame is straight. Any ideas? I have circled the cut spot.
bdrew67 is offline   Reply With Quote
Old 11-24-2012, 11:18 PM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: any ideas
Hard to tell, it looks like the engine is setting back from its normal position. I am not sure though.
Some people cut the frame to allow for header clearance, but that is just a wild guess on my part.
Hopefully some one else will chime in.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 11-24-2012, 11:28 PM   #3
midniteblues
midniteblues's Avatar
Re: any ideas
curious if that was done to make the lower rad hose fit without rubbing. perhaps they changed the rad to one with a straight outlet and they had a severe kink in the hose. with the cutout the hose probally didnt kink
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 11-24-2012, 11:28 PM   #4
speedfreak369
speedfreak369's Avatar
Re: any ideas
Radiator?
1965 c10 short stepside (dad's project)
1967 c10 fleetside 350/350 trans (my baby)
speedfreak369 is offline   Reply With Quote
Old 11-24-2012, 11:38 PM   #5
69GWC
Re: any ideas
I would guess the same, cut out to clear the rad hose, I know my lower hose sets on my frame about right in that same spot.
69GWC is offline   Reply With Quote
Old 11-24-2012, 11:55 PM   #6
bdrew67
bdrew67's Avatar
Re: any ideas
Ok that makes sense, i am going to weld a piece of steel back in there.
Old 11-25-2012, 01:00 AM   #7
Cash3481
Loves all GMC trucks
Cash3481's Avatar
Re: any ideas
Bdrew67:
It looks to me like someone bent the cross brace at some point or added the sway bar at least. I would put dimes to dollars that they couldn't cut that inside rivet and decided to cut the hole for access, just a theory though. I have a hard time getting to that rivet as well but have never cut the frame. Good luck with your build and quest for answers.
Mike
Cash3481 is offline   Reply With Quote
Old 11-25-2012, 01:23 AM   #8
c10srule
c10srule's Avatar
Re: any ideas
radiator hose be my guess, i put a rubber insulator on mine where it hits there, the rivets can be cut from the bottom with an air hammer then pushed on thru with a different bit on the air hammer from the bottom, never thought of using a heater core for a tranny cooler
c10srule is offline   Reply With Quote
Old 11-25-2012, 10:54 PM   #9
bdrew67
bdrew67's Avatar
Re: any ideas
I think you guys are right with the radiator hose, not the best way to fix it in my opinion, but the tear down has started on my project
