No No
new gears or sm465?
hi all happy thanksgiving. today I figured I would do some serious planning for the new year and what step to take next on the truck. as of now I have a a 454 in sig runs great but about 2 years ago I trashed another 12 bolt beyond repair and got stuck dumping a 3.08 12 bolt axle in to get back on the road quick. I do admit I love the low rpm highway driving so much the loss of power and minor issues in the city I can live with. I currently have a Muncie 3 speed and its about to need a rebuild. I plan on doing alot more camping this summer and that means towing which isn't bad but some places we go it would be nice to have a granny gear cause getting going fully loaded without using alot of clutch is kinda impossible. back when I had the 373 rear end it wasent to bad but these 308's are a little harder to get going with. so I was either thinking of bundling another axle or going to a sm465 which I can pickup fairly cheap. I don't want an auto and the 5 speeds I can find local either are trashed or they want over 1200 and im sure I would be itching to change the rear end ratio at the end of the day to take advantage of the 5th gear. kinda want to keep it simple and quick. anyone have have opinions either way?
Posted from 67-72chevytrucks.com App for Android
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
Re: new gears or sm465?
with the sm 465 your highway wont change if your 3 sp is non od. and then you gain the 6.33ish low gear what about getting a 14bolt with 3.73 or what ever. i have 3.42 and good all around for me. you will play hell braking a 14
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph 1985 k30 "the ice cream truck from hell" no rust az truck 197-8??? c30 "ramp truck" 454 1978 monte carlo 350 350th with 2.73 gears. no rust. sc car |
If you keep trashing 12 bolts I think that's the issue that needs to be addressed first. You need to find a good 14 bolt to swap in like mentioned above.
3.73's are pretty common in them, and frankly I find 3.73's a very friendly highway gear, with a 28" tire you can cruise at 65mph at only 2800 rpms. Add an inch to the tire and drop 200 rpms. So going with a 30" tire would knock the rpm down to the 2500 range, which is very acceptable. If it were me I'd stick with a 3.73 and fine tune the tire height to your needs so you get a good compromise between take off and highway. Then you don't have to worry about swapping transmissions as a bandaid, and you'll have a rearend you would be hard pressed to break. |
No No
thanks for the replies one major reason I was thinking of doing the trans is the current one is about in need of a rebuild. I was thinking of being nice and putting my 3 speed into the wifes buick dumping the pos Saginaw that's in there now. the reason I broke the 12 bolt was user error lol I think I grew out of that stage of my life and gas is to expensive.
#5 | |
No No
![]() Join Date: Apr 2009
I think the answer to your question is determined by what you are doing with your truck. I have an SM465 with 4.10 gears in my 83 that tows my trailer and camper but its not a performance style manual transmission. Actually the wide gear ratio's kinda suck for normal driving.
If you want to have a "Performance" setup go with a regular 4 or 5 speed trans, The SM465 has such a low first I never use it unless I'm towing. Desert |
I know the pieces fit
I'm looking for an sm465 for mine and it has 3.08's. My way of thinking is the granny low will make a gear change unnecessary, especially with 4-low available. And 3.08's are good with a 1:1 final drive. 3.73's with a five-speed is much better but also far more expensive. That could run over 2 grand easy versus a few hundred for the 465.
Posted via Mobile Device |
bruiser is right. i have been looking for a low grear 5speed and there is the nv 4500 but dam they get up there
#9 | |
No No
if you are in 4 lo you are more likly in 2for 5mph the low creeper gear i have in my c20 i can move 20k lbs will slight throttle then in to first gear. now in my k30 with 4.10 gears and sm465 in 4lo wide open it is about 3 mph i get about 25 mph in forth with 4 lo.
i find that no matter what i am doing low gear just to get moving then in ot first
#11 | |
It's more of a work horse transmission and is not something for banging gears and popping clutches. Great trans for a work truck. My personal opinion, if you want to set this up right, and you want a manual trans, you are worried about gas mileage, and you also want a lower first gear, and you also like to horse around with this thing,,,,Then you really need to just step up for a TKO600. Very strong trans, 2.84 first gear and a .64 overdrive. With 3.73's it would be perfect in first gear and in overdrive. You get the best of both worlds. Because what you are trying to accomplish otherwise is more than likely going to lean more one way than the other and a compromise will have to be made, something is going to suffer. TKO retro swaps are made for just about every chassis now and various vendors. Actually swapping one of these in a vehicle that is already a manual trans is relatively inexpensive vs a full blown swap over from an auto. |
#12 | |
![]() Desert |
No No
looks like it does a real good job. well Im not sure if I will go this route after all found another option. seems the wifes grandpa decided he shouldn't be driving anymore so it looks like I may be getting his 93 extended cab shortbox. 350 crappy 700r4 and 4x4 which I was looking at getting a 4wd but more like a Cherokee but we will see I do like the extended cab shortbox trucks
#14 | |
I would be as concerned about braking as I would gearing on that rig.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
#15 | |
No No
#16 | |
Truck is a "Camper Special" and is rated for more bed weight than it actually has on it. 1 ton everything. brakes and suspension. Tows great and has Never felt unsafe while towing or braking. Desert |
