Old 11-21-2012, 10:40 PM   #1
72BlckButy
Tot Roddin'
72BlckButy's Avatar
New Product - Accuair iLevel
I happened to be on the Accuair website and noticed that the new iLevel option has been released.
Pretty slick stuff if I do say so myself.
http://www.accuairsuspension.com/product_ilevel.html
So who's going to be the first to run this option???
Delmo? Dino? n2billet?
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 11-21-2012, 10:41 PM   #2
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: New Product - Accuair iLevel
PDF fact sheet...
http://www.accuairsuspension.com/pro...tasheetV03.pdf
-Nate
Old 11-21-2012, 10:44 PM   #3
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Looks like Andriod version will be available Mid-2013.
-Nate
Old 11-22-2012, 12:46 AM   #4
Painter D
Painter D's Avatar
Well if it was on the Android market now , I'd whip out the ole credit card and go first but I guess I'll have to wait a few months.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs)
'63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs)
http://67-72chevytrucks.com/vboard/s...=528853&page=5
Painter D is offline   Reply With Quote
Old 11-22-2012, 09:53 AM   #5
Pro Performance
Pro Performance's Avatar
Here is a demonstration video from SEMA.
Pro Performance is offline   Reply With Quote
Old 11-22-2012, 01:30 PM   #6
jmedero
jmedero's Avatar
What sucks about it is it does not work with the switch speed set up. That's what I've been planning on running the whole time.
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 11-22-2012, 03:32 PM   #7
502ms
502ms's Avatar
I am intrigued. I might...
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 11-24-2012, 04:25 PM   #8
72BlckButy
Tot Roddin'
72BlckButy's Avatar
No kidding... considering the switch panel is teh same for hte e-level and the switch speed, I don't understand their reason for doing this. Well, other than to sell more e-level kits.
-Nate
Old 11-26-2012, 10:20 AM   #9
Hart_Rod
Hart_Rod's Avatar
Hart_Rod is offline   Reply With Quote
Old 11-26-2012, 01:41 PM   #10
STPrider
STPrider's Avatar
True, I could see why lot of guys would go with switchspeed and the phone. Looks like a really cool, functional upgrade though! When I first read about the development in the accuair blog it seemed like something you could show off with, but the popup diagnostics and ease of use for setting your saved heights seems like a really good idea!
'71 GMC pickup; "Ashley,"
STPrider is offline   Reply With Quote
Old 11-26-2012, 01:46 PM   #11
goldietucson
goldietucson's Avatar
yeah me and my friend wanna get this for our trucks i dont even have a i phone i just like all the other features
goldietucson is offline   Reply With Quote
Old 11-26-2012, 02:19 PM   #12
jimmydean
jimmydean's Avatar
Waiting for android...
There is a big reason Android phones make up 70% of the market. But folks on iOS are used to paying a lot for apps, too.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 11-26-2012, 02:59 PM   #13
72BlckButy
Tot Roddin'
72BlckButy's Avatar
I guess Accuair's claim to fame is that you don't have to worry about air pressure.
Is there a reason they won't incorporate air pressure readings at each bag and/or the tank? I personally have never owned and/or operated a vehicle on air ride, but to me it would be a good fail safe to have available.
-Nate
Old 11-26-2012, 07:06 PM   #14
STPrider
STPrider's Avatar
Well Accuair's thinking is that it truly doesn't matter. I am in the process of installing the e-level, and I'm running a tank pressure guage seperately from my tank. I would think it would be cheaper to have a T in all of your air lines and run lines to guages in your cab than for Accuair to incorporate pressure sensors into their high-tech VU4 valve block. Rather than Accuair having to re-design, it would cost 15$ per guage, plus a few bucks in lines and fittings.
Old 11-27-2012, 06:31 PM   #15
jimmydean
jimmydean's Avatar
On my '69 I had a tank gauge and 2 dual needle gauges for the bags (front left/right, rear left/right). I will have some sort of gauge just for sanity.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 11-27-2012, 07:46 PM   #16
jmedero
jmedero's Avatar
I guess another issue I have is if your level at what ever height but your pressure is all over the map does that make a diff?
Lets say your sitting perfectly level.
Ft lt 60
Ft rt 48
Rr rt 62
Rr lt 44
Wouldn't that make it a little wonky when driving let say 55mph? Now mind you I'm only an Astro Physicist so I might be wrong lol
Old 11-27-2012, 07:59 PM   #17
jimmydean
jimmydean's Avatar
Ft lt 60
Ft rt 48
Rr rt 62
Rr lt 44
IMO if you are level with pressure off by more than +/- maybe 2psi, then you should check the floor in your shop for level.
My '69 was something like 45psi front and 30psi rear at ride height and while I didn't have a level system in my truck, it "looked" even.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 11-27-2012, 11:16 PM   #18
gofast68c20
Has anyone ordered/received the i-level setup?
gofast68c20 is offline   Reply With Quote
Old 11-30-2012, 09:55 AM   #19
blazins10
blazins10's Avatar
i was told it wont start shipping untill dec 10th but i played with it
at sema and its very cool and yes it only works with e level setup but
they will be offering an upgrade for non leveling systems that just reflash
your ecu and controller and add in the height sensors
///Relaxed Atmosphere
blazins10 is offline   Reply With Quote
Old 11-30-2012, 10:06 AM   #20
gofast68c20
Got an email from Reno yesterday saying they are hoping to ship middle to end of next week. I can't wait!!
Old 12-06-2012, 01:27 PM   #21
slimneverdies
slimneverdies's Avatar
for some reason I cant find the ilevel app in the app store
Long live SLIM
At least try to buy American
slimneverdies is offline   Reply With Quote
Old 12-06-2012, 01:51 PM   #22
jimmydean
jimmydean's Avatar
It doesn't seem to be available yet based on my searches of the US and Canada app stores.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 12-06-2012, 04:09 PM   #23
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Anyone own this and/or using it?
The public has spoken and we want details.
-Nate
Old 12-06-2012, 05:10 PM   #24
edflores
I am waiting on this too. They havent replied to emails about when they will ship
edflores is offline   Reply With Quote
Old 12-06-2012, 08:30 PM   #25
gofast68c20
Direct quote from Accuair on Instagram today "We want to thank everyone who made their preorder purchase of the Accuair iLevel. The first round of parts are in final assembly, and the app should be live in the Apple App Store next week!"
