Closed Thread
Old 11-25-2012, 12:58 AM   #6551
a37lesalle
a37lesalle's Avatar
Re: What did you do to your truck today?
Well decided to run down the electrical problems. With all the previous posts on electrical it was easy to find the biggest problem. On the backside of the fuse block I found the power wire into the block corroded and completely apart. That was a easy fix. It was not long I had to unwrap the wires under the dash. There I found wires cut and spliced where they didn't do any good. Two days into the electrical and I think I can wrap it up. Finally got turn sigs, tail lights and all.
a37lesalle is offline
Old 11-25-2012, 01:12 AM   #6552
mud.man.rj
mud.man.rj's Avatar
wow, good for you on the electrical. Wiring, I do a lot of and still is no fun, slow time consuming isn't it. Cool your getting close to done.
mud.man.rj is offline
Old 11-25-2012, 07:21 AM   #6553
a37lesalle
a37lesalle's Avatar
oh yea very time consuming and not fun. However I do get a chuckle when I find things that make no sense. But thanks to everyone that posts on here it was an easy job.
Old 11-25-2012, 04:34 PM   #6554
LT1 Burb
LT1 Burb's Avatar
Just cleaning up parts.
LT1 Burb is offline
Old 11-25-2012, 05:01 PM   #6555
dantimdad
dantimdad's Avatar
Man! Those look sweet!
Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla
Matt. 6:27 "Who of you by worrying can add a single hour to his life?”
http://www.67-72chevytrucks.com/vboa...=507266&page=2
dantimdad is offline
Old 11-25-2012, 05:57 PM   #6556
Rac65
Started metal work on my hood. Would like to buy the replacement pieces but unfortunately my finances won't allow it so I am making the pieces I need and doing the best I can. It's a slow process but I will get there eventually.
Rac65 is offline
Old 11-25-2012, 08:04 PM   #6557
Woogeroo
drove about 90 miles home...
-W
Woogeroo is offline
Old 11-25-2012, 11:34 PM   #6558
sdcfish
Washed, polished, and hung out at the Woodland Hills, CA car show hang out....Jay Leno came by with an amazing "Tank" car.....had a 12 cylinder Patton tank engine diesel in it....very cool. Came home and took out an intake manifold bolt that had been leaking some oil and re-sealed the bolt and is currently setting over night....hope that seals that nasty oil leaker....just enough oil to smell when you are cruising....don't you hate that? Now she's resting nicely under the cover
sdcfish is offline
Old 11-26-2012, 08:18 PM   #6559
dantimdad
dantimdad's Avatar
Got a big pile of parts back from the blaster tonight:
I didn't want to unwrap them all but had to peek:
My buddy did an incredible job!
He did all 4 control arms, front coils, front backing plates and crossmember.
Total cost: FREE!
Tomorrow night is a marathon painting session so they don't flash rust.
Steven
Old 11-26-2012, 08:26 PM   #6560
jbgroby
jbgroby's Avatar
Depending on your humidity in your region, get some coating on them quickly. In the gulf south, you can sit down and actually watch them start to rust.
jbgroby is offline
Old 11-26-2012, 09:09 PM   #6561
dantimdad
dantimdad's Avatar
They are wrapped and it should slow it down enough until tomorrow night.
Makes me wish I would have spent $90K on the blasting setup his company has instead of a house! LOL!
Steven
Old 11-26-2012, 09:56 PM   #6562
Andice
Andice's Avatar
We finally got some paint on the dash today. The rest of the interior is painted as well. One step at a time.
Andice is offline
Old 11-27-2012, 12:23 AM   #6563
jbgroby
jbgroby's Avatar
Good Looking GMC. Ain't it a great feeling to see progress.
jbgroby is offline
Old 11-27-2012, 10:03 PM   #6564
PORKY
PORKY's Avatar
We finished putting on base coat for both colors today. We hope to clear it all tomorrow.
PORKY is offline
Old 11-27-2012, 10:25 PM   #6565
dantimdad
dantimdad's Avatar
The suspension parts are going to be silver and hammered black.
Got all the silver parts done tonight. Here are a couple pics of some of them:
Tomorrow night my son and I will paint the hammered parts.
Steven
Old 11-28-2012, 04:04 PM   #6566
PORKY
PORKY's Avatar
We got 4 coats of clear on today with only one small run inside the box.
PORKY is offline
Old 11-28-2012, 04:09 PM   #6567
MisterC
MisterC's Avatar
That looks sooo nice! Congrats!
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline
Old 11-28-2012, 04:18 PM   #6568
sdcfish
Looks awesome! What kind of clear are you using? Being in Los angeles, we have to spray water based paints, and I used a new PPG water based clear...$375 per gallon....used 1 1/4 gallons for the fleetside 65 c20.....I still have most of the 2nd gallon left!
sdcfish is offline
Old 11-28-2012, 10:48 PM   #6569
PORKY
PORKY's Avatar
We used Napa Martin Senour, TC751 Clear, with TS3 Tec solvent#3, and
8876 hardner. I'm in northern NH, 28 degrees here today. When I started painting shop was 70 degrees. Whne I finshed after running the fan and with the make up air doors open the shop was 40 degrees.
PORKY is offline
Old 11-28-2012, 10:54 PM   #6570
198plus
198plus's Avatar
I installed my new Ansen valve covers.
198plus is offline
Old 11-28-2012, 11:09 PM   #6571
198plus
198plus's Avatar
Looks nice !!!! Wish I would have done mine black, but you never know I might change my mind
198plus is offline
Old 11-28-2012, 11:17 PM   #6572
PORKY
PORKY's Avatar
NICEEEEEEEEEEEEEEEEEEE. I love those big blocks. That's what we will be doing. We already have the Tremec 5speed. We are thinking either the 427 or a 502, new from GM. What do you run for a tranny?
PORKY is offline
Old 11-28-2012, 11:55 PM   #6573
198plus
198plus's Avatar
I have a turbo 400.
198plus is offline
Old 11-29-2012, 12:32 PM   #6574
63c10step
Haven't posted in awhile. I have recently put steering wheel, intermediate shaft in. Put seat back in. Installed new front and back glass.
Also, took her around the block for 1st ride since I started tearing down over a year ago!!! Smiled from ear to ear!! Still got along way to go. Here are a few pictures:
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
63c10step is offline
Old 11-29-2012, 01:28 PM   #6575
glos55
glos55's Avatar
It's All Good on this page!!!!
LIFE IS SHORT HAVE FUN
glos55 is offline
Closed Thread
