#1 | |
Re: How Many Miles Per Tank?
#2 | |
Probably best to use a calculator and decide what fits you best. Your 4th gear overdrive in the 700 is .70. That along with your prefered tire height, and the lockup converter, makes a 3.73 very streetable in my opinion. You can go to Vexer.com and use their speed calculator, play with tire height and gearings and watch how it affects speed and rpm, it's an interactive screen that's pretty cool. Hang on and I'll see if I can link it.... |
http://vexer.com/automotive-tools/speed-rpm-calculator
Here you go. I plugged in your .70 overdrive with a 28" tire, converter locked up at 100% efficiency, and 3.73 gears and it says 2200 rpms for a 70 mph cruise speed. Of course it would be lower if you run say,,,a 30" tire...it drops to 2,000 rpms at the same speed. Plug in some different stuff and move the slider around and see what you think. |
#4 | |
