11-29-2012, 10:47 PM | #1 |
85 s10 with newer grill
i have a 85 s-10 pickup and would like to put a 91-93 one piece grill in it. will it fit in mine without much cutting or fabbing? thanks for any help you guys may have
RAYZDUPNCREWZN 1985 CCSB 4X4 |
11-29-2012, 11:20 PM | #2 |
Location: Marshall, NC....heart of the Appalachians.....aka, Gods country!!
Re: 85 s10 with newer grill
it will fit, however the headlight buckets on the 82-90 sit lower on the radiator support, so there will be about a 3/4 inch gap above the headlight. you can either section the radiator support and move the HL bucket area up or swap in a 91-93 radiator support into the truck so everything will look right or live with the 3/4 inch gap.
11-30-2012, 01:11 PM | #3 |
Mine is here -
http://www.s10forum.com/forum/f135/3...-grill-506997/ |
11-30-2012, 06:16 PM | #4 |
thanks guys for your imput. what do you have to do to the metal panel (valance?) just below the grill? or does the newer grill cover it up?
12-01-2012, 12:46 AM | #5 |
the 91-93 grill takes place of the 82-90 filler panel, center grill and headlight bezels......so basically just pull everything off and the 91-93 one piece grill goes in its place......you just have to decide if you can live with he 3/4 inch gap above the headlight if you use the original core support.
