Old 11-26-2012, 11:07 AM   #1
smoky02
Location: Sunny, Florida, some might call it South Alabama
5th Gen Camaro
Will 5th Gen Camaro long tube headers work on a LS swap in a 1968 Truck? I have seen them mentioned but didn't see where someone said if they will or won't work.
Thank you,
TSgt Turner
Just sold my C10...sad day...
Looking for a 1972 Blazer to hopefully fill the hole in my heart.
smoky02 is offline   Reply With Quote
Old 11-27-2012, 09:10 AM   #2
smoky02
Re: 5th Gen Camaro
Does anyone have any input on this?
Old 11-27-2012, 10:02 AM   #3
Clyde65
Clyde65's Avatar
Re: 5th Gen Camaro
What about Doug Thorley long tubes? is there a reason you are wanting the F-body headers?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 11-27-2012, 10:19 AM   #4
smoky02
Re: 5th Gen Camaro
I can get a set of stainless long tubes for a camaro for around $350. That is why. Otherwise I will more than likely be using Trail blazer SS headers. But I thought I would ask and see if anyone had tried it and had any luck.
Old 11-29-2012, 10:05 PM   #5
smoky02
Re: 5th Gen Camaro
bump
Old 11-30-2012, 02:54 PM   #6
Nitschke
Nitschke's Avatar
Re: 5th Gen Camaro
I think the 4th gen fit good i will be getting a set soon from Amazon ceramic coated they are like $352. Ill see if i can find the posts that i read about them.
~72 Chevy Truck~
Motor: LY6 6.0 Liter
Trans: 6L80E
Still under construction
Nitschke is offline   Reply With Quote
Old 11-30-2012, 05:14 PM   #7
bohmankid
bohmankid's Avatar
Re: 5th Gen Camaro
I put 5th gen long tubes on my 85 gmc. Mine is a 4x4 but here are some pics, maybe it will help you figure out the dimensions a little better. I picked them up for $250 off Ebay.
These last two pics show how the collectors dip a little lower than the crossmember. But your application will be different. Either way, cutting off the collectors and re-welding them will be easy.
bohmankid is offline   Reply With Quote
Old 11-30-2012, 05:16 PM   #8
bohmankid
bohmankid's Avatar
Re: 5th Gen Camaro
In those pics above it looks like it's a tight squeeze, but there is LOADS of room so don't be fooled. Also, I'm using Dirty Dingo motor mounts.
Old 12-01-2012, 12:39 PM   #9
smoky02
Re: 5th Gen Camaro
Thank you. And I wonder how much different the setup is on mine. Thank you replying. And that is what I was looking to see.
Old 12-01-2012, 12:39 PM   #10
smoky02
Re: 5th Gen Camaro
Hopefully some more people have done it. And on my year truck.
