Old 12-01-2012, 09:22 AM   #1
custom97
custom97's Avatar
Need help
Well, I started on my intake gaskets and now I can't get my distributor to fall on my marks. Am I missing something? I didn't disturb the engine at all?
custom97 is offline   Reply With Quote
Old 12-01-2012, 09:27 AM   #2
speedygonzales
speedygonzales's Avatar
Re: Need help
Did you line up #1 at TDC?
99 Z71 (98 body style)
Pride and joy
speedygonzales is offline   Reply With Quote
Old 12-01-2012, 09:34 AM   #3
custom97
custom97's Avatar
Re: Need help
No I didn't. Didn't think I had to if the truck waz running great except for the leak.
Old 12-01-2012, 10:50 AM   #4
speedygonzales
Re: Need help
Would have made the job easier to just line up the rotor with the tiny number on the side of the housing.
Otherwise you have to turn back slightly cause the rotor will rotate as it's dropped in. I used to put a mark on the fire wall and from the rotor to the dist housing. Till I learned that you have to do the cam retard offset adjustment anyway.
Instructions here cam retard
Which will require a scanner that can do real time sensor data not a simple code scanner.
Pride and joy
Old 12-01-2012, 11:58 AM   #5
bk2life
Re: Need help
turn your rotor back a bit and redrop it in. the cam gear/and dist gear are cut on a helix, therefore the entire dist shaft will move/rotate going in the engine.
bk2life is offline   Reply With Quote
Old 12-01-2012, 03:13 PM   #6
custom97
custom97's Avatar
Re: Need help
I've done that already and I'm still off from my original marks I did on the base of the distributor and rotor to distributor. I rotated the oil pump shaft to try to get it to fall, but it just won't. Frustrating job. Anybody on here from NW part of Houston that can lend me hand?
Old 12-01-2012, 06:40 PM   #7
wayfastwhitey
right below above average joe
wayfastwhitey's Avatar
Re: Need help
Just get it as close as you can and clock the distributor until one of the posts line up to the rotor near your original mark and go from there. Or you could just set it to tdc and do it like that.
i flush the of weakness with mushroom clouds at hand
'95 short bed x cab c1500...
just another old truck someone else beat up, abused, hacked and didnt respect... my turn to turn it into a beat up old truck into a beat up and reliable pleasure to drive...
them- "when you gonna put an exhaust on that thing?"
me- "what do you mean? The exhaust comes all the way to the bumber and sounds great!"
them- "straight pipes isnt an exhaust man..."
me- "meh... who needs a fancy muffler when you've got straight pipes? its got a cat, doesnt resonate, and I like how it sounds, and to be perfectly honest, it makes me behave myself when I'm out and about!"
^^^ favorite conversation about my truck to date
wayfastwhitey is offline   Reply With Quote
