Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1967-1972 Chevrolet & GMC Pickups Parts Board > Blazer and Suburban Stuff
Old 12-01-2012, 09:36 PM   #1
texas04
texas04's Avatar
WTB Rear Hatch Handle Hardware
Like the title says, I am looking for the hardware (specifically the handle, spring and retaining washer) for the double wall hatch on my 72 Blazer. I am tracking that I can get a replacement handle from Brothers or a hardware store, but the rest of my original assembly rusted into oblivion. I am also open to anybody's ideas on how to replicate the parts on my own. I'm sure plenty of forum members have tackled this before. Thanks.
1972 CST K5 Blazer
texas04 is offline   Reply With Quote
Old 12-01-2012, 10:09 PM   #2
texas04
texas04's Avatar
Re: WTB Rear Hatch Handle Hardware
Here is a picture of what I am working with...
1972 CST K5 Blazer
Old 12-01-2012, 10:40 PM   #3
texas04
texas04's Avatar
Another pic...
Name:  handle pic 2.jpg
1972 CST K5 Blazer
Old 12-02-2012, 11:02 PM   #4
72K5NTX
72K5NTX's Avatar
I guess I need clarification... do you need the latches and the rods or the metal plate with the square hole the rods attach to? Or do you need the mounting bracket that the whole assembly attaches to inside the top by the bolts that go through the sill of the hatch. I bought the one from Brothers, it is the same one you get at Lowes, just 30 buck higher. I did not have a handle at all and used the one from Lowes.
72K5NTX is offline   Reply With Quote
Old 12-02-2012, 11:26 PM   #5
texas04
texas04's Avatar
I found a handle at Home Depot earlier today. Like you said, the same as what Brothers is selling just cheaper. Now what I need is the metal plate with the square hole that the rods attach too, and the spring that wraps around the rod behind the handle. I've got the mounting bracket and the rest of the hardware, it's just all the parts that are on the handle that are shot.
1972 CST K5 Blazer
Old 12-02-2012, 11:39 PM   #6
72K5NTX
72K5NTX's Avatar
I see. I don't have that part. I don't have a spring in mine at all and it works pretty well. It does not spring back like original but the outside latches pull it back straight when closed and latched. As far as the rod attaching plate goes, I think you could make it, the only prob is the square hole. A fabrication/welding /machine shop maybe? Trust me I feel your pain I drove mine with no hatch for about 2 years because of the handle and the hinge mounting plates being roached. I would pull it all out and shoot you some measurements but it would be quite painful for me now that its all together and works well. Somebodies gotta have one apart here that could give you a template though.
Old 12-02-2012, 11:44 PM   #7
texas04
texas04's Avatar
No worries, I appreciate the input. Do you have a recommendation for a fabrication/machine shop in Dallas?
1972 CST K5 Blazer
Old 12-03-2012, 08:06 PM   #8
Mint68
Mint68's Avatar
Here is what I have in my bag of extra hatch parts, I think I may have some of the metal plate/covers as well . If any of this is what you need let me know. One of the handles was cut off in the plate it goes through, the piece is siezed in there, but would probably come out with some work.
Mint68 is offline   Reply With Quote
Old 12-03-2012, 09:49 PM   #9
texas04
texas04's Avatar
Mint 68, can you send me a better pic of the circled item? It looks like one of the pieces I need, hard to tell without getting a closer look. Is that the plate with the cut off piece you are referring to?
1972 CST K5 Blazer
Old 12-03-2012, 11:49 PM   #10
Mint68
Mint68's Avatar
try this one, the siezed piece is held to the bracket with a snap ring.
Old 12-04-2012, 01:39 AM   #11
72K5NTX
72K5NTX's Avatar
I think there is a pin under the spring that holds the square shaft in there but not positive. Man where were these good ole parts last Summer???
Old 12-04-2012, 09:32 AM   #12
texas04
texas04's Avatar
Mint 68, those are the parts I'm looking for. How much for the parts pictured above shipped to 75229? Thanks.
1972 CST K5 Blazer
Old 12-04-2012, 12:26 PM   #13
Mint68
Mint68's Avatar
sending pm texas04
Old 12-19-2012, 09:15 AM   #14
Dale99
mint, pm sent as I see a part I would like if you dont mind.
Dale99 is offline   Reply With Quote
Old 12-19-2012, 05:07 PM   #15
4oldcars
4oldcars's Avatar
If anyone else reading this has that same part, I need one. I'm confused where that snap ring came from?
4oldcars
Driving:
1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado
The ones I let go:
1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed
4oldcars is offline   Reply With Quote
Old 12-19-2012, 06:15 PM   #16
mgkgmc
mgkgmc's Avatar
I have a extra set of hatch latch rods that connect the handle to the hatch latches in good shape if your interested.
1970 GMC 1500 stepside
1972 GMC Jimmy Custom
2004 Chevy Colorado
1989 Swb Silverado
1972 Aj's Stormer
mgkgmc is offline   Reply With Quote
Old 12-20-2012, 05:26 PM   #17
LockDoc
The Older Generation
LockDoc's Avatar
I don't know if this will help anyone or not but here is an FAQ I posted about disassembling the handle to get the lock cylinder out.
http://67-72chevytrucks.com/vboard/s...d.php?t=509656
LockDoc
Leon
Old 12-22-2012, 11:37 AM   #18
4oldcars
4oldcars's Avatar
I'm still tryin to figure out how to separate the spring and rod bracket from the handle shaft so the handle can be removed from the hatch
4oldcars
Driving:
The ones I let go:
Old 01-18-2013, 08:03 AM   #19
PD1292
PD1292's Avatar
mint68, Would you be so kind as to take a better picture of this part. I think it is almost gone in my hatch. i think i am going to have to attempt to split the top to make a piece like this to replace the missing part. thanks. barry.
PD1292 is offline   Reply With Quote
Old 09-11-2013, 01:48 AM   #20
RideSF
Does any body have a handle for sale refinish able?
RideSF is offline   Reply With Quote
Old 02-12-2016, 08:32 PM   #21
sviray
sviray's Avatar
Anyone have extra one to sell? Please pm me, thx!
'71 2wd K5 BLAZER
sviray is offline   Reply With Quote
Old 02-12-2016, 08:38 PM   #22
sviray
sviray's Avatar
bracket with 2 bolts is what I am looking for...thx in advance!!!
'71 2wd K5 BLAZER
Old 07-15-2017, 10:57 PM   #23
glenn_grrd@yahoo.com
I need the pivot spring assembly, if anyone has one or a lead to one, please email or pm me.
glenn_grrd@yahoo.com is offline   Reply With Quote
Old 07-16-2017, 11:19 AM   #24
1rippen6
http://67-72chevytrucks.com/vboard/s...d.php?t=742121
1rippen6 is offline   Reply With Quote
Old 07-17-2017, 09:30 AM   #25
Jesse B.
Originally Posted by 1rippen6 View Post
As 1rippen6 pasted above (thanks!), I have a new latch assembly for sale. Click on his link.
Jesse B. is offline   Reply With Quote
