Old 12-02-2012, 12:37 AM   #1
67ctener
67ctener's Avatar
Cpp modular drop spindles and wheel backspacing
Hey guys I've got a 67 with cpp modulAr spindles. I'm wanting to get wheels but don't wanna assemble the truck to measure. Anyone Running this set up with a 20x8.5 in the front and could tell me an offset? Any help is appreciated
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
67ctener is offline   Reply With Quote
Old 12-02-2012, 12:41 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Cpp modular drop spindles and wheel backspacing
I can tell you backspacing.
20x8.5 with 5.25"-5.5" backspace would be my choice.
Keith
Convert to disc brakes.
Old 12-02-2012, 12:46 AM   #3
gringoloco
A guy with a truck
gringoloco's Avatar
With modulars? Aren't they 3/4" narrower? That would put you at 4.75-5" BS, no?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 12-02-2012, 12:49 AM   #4
67ctener
67ctener's Avatar
This is what I was thinking. I see majority of people are running 5 1/4 with non modulars, hoping there is someone here with my exact set up. Thanks for the help
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
Old 12-02-2012, 12:51 AM   #5
67ctener
67ctener's Avatar
I see most everyone is running 5 1/4 but with the modulars and narrowing the track width would I be at 4.5? I think they say it will bring my wheel in 3/4"
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
Old 12-02-2012, 12:51 AM   #6
shawno72
C/10 junkie
shawno72's Avatar
Curious as well
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 12-02-2012, 12:53 AM   #7
lolife99
lolife99's Avatar
I have never seen anyone post actual numbers for the CPP Modular spindles.
I've seen the chart that CPP put out,... but it has some issues.
If they are 1/2" narrower than a standard drop spindle,... I would be surprised.
Non modular spindles,... I would run a 20x8.5 with 5.75" BS just like n2billet's Lucy had.
Keith
Old 12-02-2012, 12:55 AM   #8
67ctener
67ctener's Avatar
Man Thats a beautiful truck
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
Old 12-02-2012, 12:59 AM   #9
lolife99
lolife99's Avatar
I run 5-1/4 BS on my 20x8 wheels on the blazer.
Keith
Old 12-02-2012, 01:01 AM   #10
67ctener
67ctener's Avatar
Is that with the cpp spindles?
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
Old 12-02-2012, 01:02 AM   #11
67ctener
67ctener's Avatar
Great lookin blazer
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
Old 12-02-2012, 01:10 AM   #12
lolife99
lolife99's Avatar
No,... ECE.
Keith
Old 12-02-2012, 04:34 AM   #13
derrickmanx1
derrickmanx1's Avatar
I got the 2.5's from CPP. I'm hoping to be able to run 18x9.5 w 5-5.5 bs on all four corners.
NAME: TRAVIS TRUCK: BRUISER
71 C/10 SWB 3.5/5" drop 4.11 GEARS.
F.A.S.T. BBC 408 496hp/479ft/lb
JAKES 4L80E TCI TCU PTC 10.5" 2800 STALL
My build thread: http://67-72chevytrucks.com/vboard/s...30#post5779530
derrickmanx1 is offline   Reply With Quote
Old 12-02-2012, 12:05 PM   #14
67ctener
67ctener's Avatar
Let me know if it works out
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
Old 12-02-2012, 04:33 PM   #15
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
I am interested in this too as I have the 73-87 control arms and drop spindles. My existing setup has the wheel/tire too far outward and it rubs a lot. I want to center them more in the inner fender.
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 12-02-2012, 04:36 PM   #16
67ctener
67ctener's Avatar
Someones out there had gotta have a straight answer for us haha
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
Old 12-02-2012, 05:09 PM   #17
lolife99
lolife99's Avatar
Here's the thread with the CPP offset chart.
http://67-72chevytrucks.com/vboard/s...d.php?t=529285
It says,...
Standard CPP Drop Spindles:
* 1/16" wider than DRUM BRAKES.
* 7/16" narrower than factory DISC BRAKES.
CPP Modular Drop Spindles:
* 1/4" narrower than DRUM BRAKES.
* 3/4" narrower than factory DISC BRAKES.
Also states at the bottom of the 73-87 chart that Western Chassis drop spindles are:
* 7/8" wider than DRUM BRAKES.
* 3/8" wider than factory DISC BRAKES.
Never on the chart does it say "per side" or "total track width narrower/wider".
If I had a set of the Modular Spindles,... I would measure them against a set of Belltech spindles I have and would put an end to all of this.
Keith
Old 12-02-2012, 05:15 PM   #18
lolife99
lolife99's Avatar
I have a hard time believing CPP's standard drop spindles are only 1/16" wider than the drum brake set-up.
The design of the spindle will have to widen the track width.
Plus CPP takes into no account the fact that drop springs or cut springs will also widen the track width, as the lower control arm "flattens out" due to the shorter spring.
Keith
Old 12-02-2012, 05:30 PM   #19
lolife99
lolife99's Avatar
Here's another thread that adds to the confusion,... with a member saying that CPPJEFF said,... it move the wheels in 3/4" per side,... (again COMPARED TO WHAT?)
1) Drum brakes?
2) Stock OEM Disc Brakes?
3) Other Drop spindles?
http://67-72chevytrucks.com/vboard/s...d.php?t=401544
But yet,... in the same thread,... there is a quote from CPP's website:
Modular™ Drop Spindle Wheel Kits
Looking for a spindle and brake kit for your lowered truck with big tires and wheels?
We have it!
Introducing CPP's new modular 2" drop spindle and drop spindle wheel kits for 1960-87 Chevy pickups.
Our exclusive new design helps solves tire to fender interference commonly found with lowered trucks.
Our new modular spindle and bracket works with factory 1971-87 C10 brake components, or for a HIGH performance option, combine our spindle with the NEW CPP 13" Rotor Twin 52mm Piston Brake Kit.
The ALL NEW CPP Modular Spindle offers many benefits available for the first time, installs easy without modifications, works with factory ball joints and tie rod ends, lowers your truck a full 2", offers adjustable steering stops, provides 1-1/8" more fender to tire clearance, allows use with standard factory brakes and PERFORMANCE aftermarket "BIG" Brake Kits.
You can count on CPP for impressive quality, performance and price.
Drop spindles also sold separately.
Ok,... so my math skills say that 1-1/8" is only 9/16" per side.
So what is it?
And compared to what?
All I can say is these CPP Modular spindles are the narrowest drop spindles out there for the 60-87 trucks.
But they are only an advertised 2" drop.
So back to what I always say.
Install them and then,... measure your own truck for wheels.
There's no other "sure fire way",... than that.
Keith
Old 12-02-2012, 05:43 PM   #20
67ctener
67ctener's Avatar
Thanks for all the help/effort keith
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
Old 12-02-2012, 05:44 PM   #21
67ctener
67ctener's Avatar
Geary has about the same setup on his butternut yellow 69 but he is running western spindles idk where cpp/western are compared on width
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
Old 10-13-2014, 07:34 PM   #22
dkauffman05
dkauffman05's Avatar
What ever came of this . I'm about to order wheels and was gonna run the modular spindles because I thought it was gonna narrow my track width 3/4 so I can get a deeper back spacing wheel. Also I'm wanting to run a 18x9.5 on the front if I can.
dkauffman05 is offline   Reply With Quote
Old 01-20-2016, 04:00 PM   #23
StupudMunkee
Realize this is an old thread, but I think the information may be useful as folks are searching the site.
Just spoke with Van @ CPP, he said that the statement "provides 1-1/8" more fender to tire clearance" is a comparison to other vendors' kits. Assume he meant drop spindle there but he could have been talking about the CPP Big Brake Kit with Modular Drop Spindles as a full setup. He also said that people have measured after install with as much as 3/8" change in either direction.
StupudMunkee is offline   Reply With Quote
Old 01-20-2016, 04:19 PM   #24
lolife99
lolife99's Avatar
So no definite answer from CPP,...
Keith
Old 01-20-2016, 04:21 PM   #25
StupudMunkee
Nope. It sounded like they'd heard the question 1,000 times and were irritated that I'd called to ask about it for 1,001.
