Old 12-02-2012, 07:20 AM   #1
dug224
dug224's Avatar
What is the best steering column & pedal assembly for my '59 Fleetside
Getting close to needing the emergency brake pedal, brake pedal assembly and steering column for my '59. Intend to get one out of an old car or truck at one of the U-Pull-Its.
Question: What are the most common units to use that fit with the minimum amount of modification?
My gas pedal will be a fly by wire to match my modern frame swap so I am not in need of this. Need e-brake, brake and steering column only. My '02GMC Envoy frame has the e-brake cables and steering shaft (to rack) in place. The steering shaft appears to be in perfect alignment with the cab opening. I like the modern banjo style steering wheel and will buy one if I can't find an older unit from the '50's....thx dug
dug224 is offline   Reply With Quote
