steering column
my 82 c10 has a tilt wheel but the tilt is broke need to know what year columns can i use is it till 1990 thanks
Posted via Mobile Device |
Re: steering column
79-83 should be a direct swap, has double D shaft to connect to intermidiate shaft.
84-87rc/91cc,burb,blazer have wiper switch on blinker stalk, has double D shaft to connect to intermidiate shaft. 73-78 have splined shaft to connect to intermidiate shaft.
John 82 Chevy Silverado 350ci/TH350 ![]() |
Re: steering column
thanks
Re: steering column
just call a column repair guy to fix yours. itll be easier, cheaper in the long run, and you already have it.
you get a new used cloumn its probably broken or going to break. why chance that? |
Re: steering column
so does that mean you cant use a 90's steering column in a 77 truck, bcause everything is connected but im having trouble putting it in gear.
Robert Olson Transport
![]() Join Date: Oct 2002
Re: steering column
make sure you can get the lower shaft with a replacement column I had that problem
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
Re: steering column
78K & 79C Jimmys
Re: steering column
upper to lower shafts the connection changes but the total shaft will swap
I just pulled my 88 tilt for the 78
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
Re: steering column
78K & 79C Jimmys
Re: steering column
key one click fwd should release it,the wheel and shifter,
two lights the dash,three starts straighten out the tilt try a little left to right when turning the key?
Re: steering column
