12-02-2012, 10:54 PM | #1 |
Will a 1964 Grill fit on a 62?
trying to test fit a chrome 64 grill on my 62 and there appears to be no way it will fit, the center brackets pust the grill way out at the bottom, anyone ever have this issue?
12-03-2012, 02:35 AM | #2 |
Re: Will a 1964 Grill fit on a 62?
do you have a pic of the brackets?
12-03-2012, 10:00 AM | #3 |
Yes, the grill will fit. The mounting holes for the 62 grill are different than the 64, but the grill support panel is the same. Just have to drill a few holes to mount it.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
12-03-2012, 06:38 PM | #4 |
1961 crewcab
the only time I had this issue was when I was trying to mount a c/50-80 grille in my c/10
this might be the case. otherwise other than drilling a few holes you should be able to bolt it in no problem.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
12-03-2012, 09:37 PM | #5 | |
Current Vehicles: '62 C10 - 350 (current project), '03 Tahoe (C Series) Some Past Projects: '69 Nova - 350 , '70 1/2 Camaro Z28 - LT1 350, '73 K20 Full-time 4x4 - 400 SB, '77 1/2 Camaro Z28 - 350, '84 Camaro Z28 - 305, '68 Buick - 430 BB |
12-03-2012, 09:38 PM | #6 |
Sweet looking grill!!
