Old 12-04-2012, 07:41 AM   #1
wwj75c30
wwj75c30's Avatar
straight axle help on 88 k1500
so i want to straight axle my 88 k1500 i just got i can get a axle out of a 84 k10 pretty much free and my dad said hell make me the spring mounts and all that the only problem i have is the truck is driver side drop tcase and a k10 is a passenger side drop. i heard i can run a adapter to run a np208 or np205 or a tcase out of a 88-91 suburban/blazer. now is that true? i know i can run a ford dana 44 or 60. i just wanna keep the price down since its on a budget.. lol
now any help appreciated thank guys
75 c30 silverado drw 454/th400hd d70 soon to have d60 up front
73 c20 custom deluxe sm465 14bff parts truck
wwj75c30 is offline   Reply With Quote
Old 12-04-2012, 08:08 AM   #2
andrewmp6
Re: straight axle help on 88 k1500
Yeah look around advanceadapters.com they have kits to put just about any t case on any trans.And on the spring hangers i would just buy these http://offroaddesign.com/catalog/88-...Conversion.htm and offroadunlimited.com has the shock hoops and track bar you will need.And this might help you http://www.fourwheeler.com/techartic...e_conversions/
Old 12-04-2012, 08:19 AM   #3
wwj75c30
wwj75c30's Avatar
not bad only problem is $ lol so ill end up having some made. good link tho thank you ill prob do a crossover steering kit. so ill be fine running a passenger drop tcase and axle?
Old 12-04-2012, 09:10 AM   #4
andrewmp6
with the right parts it can be done.
Old 12-04-2012, 07:00 PM   #5
kwmech
How much are you really gonna save by using the chevy front axle assy.?
You need a pass side case, move the exhaust system to the drivers side for driveline clearance. More often than not, by SASing the year model you have the truck ends up being lifted about4-5'' minimum. You run into having to clearance the driveshaft so it will not bind on full drop, even with a cv at the t-case. Suck it up and locate a ford front housing. Way easier.
Don't forget that you nave to match the gear ratios also. What size tire you plan on running?
Old 12-05-2012, 01:58 AM   #6
Gobuffalo
Gobuffalo's Avatar
Done this swap.
Use the Ford axle. Look around, Ford made a high pinion D44 & D60. Swap spindles, brakes etc. from the straight K10 over so you will have the correct 6 bolt lug pattern. Very important! Check your 88 T-case front output, some were slip yoke some were a drive flange. The flange is the easiest for your swap.
Off Road Design makes a great kit for this swap.
Hope this helps.
Gobuffalo is offline   Reply With Quote
Old 12-05-2012, 06:47 AM   #7
b454rat
Being an 88 it won't have the slip yoke front shaft. SAS and cheap don't always go together. You can use the Gm front axle, but like others have mentioned it's gonna be more work and more money. If you want to use that axle, you will need to find a pass drop 241, I think 90 and I know 91 has the VSS to make your speedo work. But I think you can swap parts from your to make it work. Also need flat top pass side knuckle. No other way to get steering. I believe the Ford axle has the flat top. Also, 99.9% sure your gonna have to regear. most of the 88-up 1/2s ton I've seen have 3.42s. Dana 44s on any sort never had that gear, that is a GM gear only. You would be better off getting the front and rear from the Ford if they are 3/4 ton. Most have 4.10s, matching wheel bolt pattern and are stronger than the GM rear.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 12-05-2012, 09:04 AM   #8
andrewmp6
If hes going that far why not go ford dana 60 and a full floater 14 bolt.
Old 12-05-2012, 01:57 PM   #9
Redcap
Seems like an awful lot of work for not much return.
Personally, I'd just buy or trade your 88 for a squarebody.
Redcap is offline   Reply With Quote
Old 12-05-2012, 03:29 PM   #10
76k10
Agreed. An 88 isn't even a nice truck like the more modern models.
76k10 is offline   Reply With Quote
Old 12-05-2012, 07:45 PM   #11
wwj75c30
wwj75c30's Avatar
i have a full float 14 bolt i might just do that and find a 60
Old 12-07-2012, 01:36 AM   #12
andrewmp6
If your going to off road the truck i would do a shave kit on the 14 bolt give you a little more ground clearance.
Old 12-07-2012, 06:30 PM   #13
wwj75c30
wwj75c30's Avatar
do you have any links for that? i renember hearing about that if i do sas ill have to do that cause id plan on taking it on some trails
Old 12-07-2012, 08:51 PM   #14
b454rat
Do a google search. Basically all your doing is cutting off the bottom then welding it up.
Old 12-08-2012, 03:46 AM   #15
beardface
beardface's Avatar
This video goes over shaving a 14 bolt. They take it pretty far, even removing a 1/4 inch from the ring gear. But i goes over the procedure.
http://www.powerblocktv.com/player/s...-09&ep_show=XT
beardface is offline   Reply With Quote
Old 12-08-2012, 04:18 AM   #16
andrewmp6
A kit like this http://www.ballisticfabrication.com/...it_p_1728.html There is a ton of kits but that one you can buy it all even the milled down ring gear.
Old 12-08-2012, 12:26 PM   #17
OldCreek
OldCreek's Avatar
Here's a Ford high boy...not sure it would or wouldn't work in your case.
http://slo.craigslist.org/pts/3459922705.html
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 12-08-2012, 10:41 PM   #18
b454rat
I'd pass on that. It's low pinion and not that hard to find. Look for a high pinion 44 or a 60 if you want to do hard core wheelin'...
