Old 12-04-2012, 06:55 PM   #1
viking427
Re: c/20 and c/30 single and dual wheel differences
Originally Posted by kwmech View Post
The 3/4 ton spindle will not accept the 1 ton caliper
You sure about that ?
http://67-72chevytrucks.com/vboard/s...25&postcount=5
Its my understanding the 1 ton calipers are the same 7" pin spacing, except larger bore and wider throat - for the 1.50" thick rotor vs. 3/4 ton 1.25" thick rotor.
As long as you keep the caliper & rotor paired together, either will bolt onto the C20/C30 spindle.
Folks only use the 77 year as a convenient reference point when sourcing parts from yards or parts stores, since it was the last year of SAE threads before the caliper banjo fitting (among other fasteners), went to metric.
viking427 is offline   Reply With Quote
