Old 12-03-2012, 01:56 PM   #26
JCampbell
Re: ? cut coils --> coils to inch ratio?
Originally Posted by shoob View Post
i ended up cutting 2.5 coils...
Whoa! Go big, or go home, eh?
JCampbell is offline   Reply With Quote
Old 12-03-2012, 02:21 PM   #27
shoob
Originally Posted by J Knight View Post
Did you cut out your bumpstop mounts? Hear is a pic of the alignment studs. (I know the shims are crooked)
no, just pulled the bumpstop rubbers. will cutting the bumpstop mount effect structural integrity of the LCA?
Originally Posted by bk2life View Post
when your lowered a lot it puts a bind on the upper balls joints, pie cutting the upper CA and relieving stress on the ball joint is necessary on stock CAs.
probably about 1.5 too much..
pictures of your set-up, suspension and other shots will help a lot. What size tires are you running?
no problems, it’s pretty common on lots of trucks.
ill snag some geometry pics today. front tires are 30x9.50, (i know, holy huge tire, and probably one of my main issues) and heres a pic of the drop on the truck.
shoob is offline   Reply With Quote
Old 12-03-2012, 03:44 PM   #28
J Knight
J Knight's Avatar
[QUOTE=shoob;5737478]no, just pulled the bumpstop rubbers. will cutting the bumpstop mount effect structural integrity of the LCA?No, they are just tacked on to it.
Holy cow, look at the negative camber. Those tires a WAY to BIG for what you are doing
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 12-03-2012, 04:31 PM   #29
bigwheel15
bigwheel15's Avatar
Yep youre gonna eat through the inside edge of tires like no tomorrow unless you swap in longer bolts to get your camber back to spec.
bigwheel15 is offline   Reply With Quote
Old 12-03-2012, 04:57 PM   #30
J Knight
J Knight's Avatar
No, they are just tacked on to the lower control arm.
Here are a few things you can do to remedy your problem.
#1. Change your front tires to something smaller like
245/60/15, 225/70/15
#2. Get another set of springs, either a 2in drop spring or a pair out of the junkyard and cut one round off the bottom wich will give you a 2in spring drop.
#3. Install your 2.5in drop spindles(I think you stated you have these). This with the 2in sping drop will give you 4.5-5in total.
#4. Cut the bumpstop mount off the lower control arms.
#5. Get a front end alignment.
John
Old 12-03-2012, 07:21 PM   #31
shoob
1. looking for tires and wheels now, i dont drive the truck but maybe 2 miles everyweek to the dump (no trash service out here)
2. ok
3.will this make the truck as low or lower than now, ex. a measured 5" drop.
4.ill be doing this tomorrow
5. just did the toe about 30 minutes ago, while forgetting to get geometry pics.
so,you guys are saying, if i keep my current spring setup, and throw the spindles on, ill lay the cross member on the ground, maybe not with these larger tires, but when i change to a smaller tire......
gotcha. thanks everyone for their help. ive never lowered a c10 before, only experiance i have is about 10 years ago lifting them, and lowered a few s10 blazers.
Old 12-03-2012, 07:51 PM   #32
KQQL IT
At the body shop.
KQQL IT's Avatar
This was 2.5 coils and no spindle.
Old 12-03-2012, 08:29 PM   #33
J Knight
J Knight's Avatar
2. ok
#3. Yes appox.
#5. You did it for nothing, you will have to do it again.
If you add the spindles with those balloon tires it will probably set the inner fender on the tires, smaller tire will probably set the lower control arms on the ground.
Are those 1ton, 3/4 ton, or 1/2ton springs in the CC that are cut 2.5 rounds? My guess is 1ton.
John
Old 12-03-2012, 09:22 PM   #34
KQQL IT
At the body shop.
KQQL IT's Avatar
Yes 1 ton's cut 2 like everyother one id dropped. It was 1" tall. Why i was shocked when Shoob cut 2.5 coils. 2 usually works.
Old 12-04-2012, 02:05 AM   #35
shoob
lol, i wanna be about 2.5" lower than your 4-door.....nice truck btw.
Old 12-05-2012, 01:49 AM   #36
shoob
is there a difference between inline 6 trucks and v8 trucks factory spring strengths?
Old 12-05-2012, 01:57 AM   #37
cory d
cory d's Avatar
i thik it was about 100 lbs in spring rate. either way, both are too soft
cory d is offline   Reply With Quote
Old 12-05-2012, 02:00 AM   #38
cory d
cory d's Avatar
from the make it handle thread. cutting more then one coil and you are better off getting soem moog 6102 or grabbing some from a scrap yard and cutting them
Spring rates for stock style C-10's seem high, but this is do to the A-arm ratio. Here are some stock spring rates
Moog # 6082 722 lbs/in 6 cyl, and light v-8
Moog # 6542 842 lbs/in std v-8
Moog # 6102 1015 lbs/in bigblock, longbed c.s.
Moog # 6104 1016 lbs/in 3/4 ton, sits 1/2" higher than #6102
Moog # 6454 1060 lbs/in 3/4t bbc, c.s, 1ton
Old 12-05-2012, 02:43 AM   #39
KQQL IT
At the body shop.
KQQL IT's Avatar
Ive always got 1 ton or 3/4 ton coils. And cut till im happy.
I wonder what the spring rate changes as you cut that much.
And im considering cherokee coils to get less spring rate and more stored energy for a better launch at the strip.
Old 12-05-2012, 02:30 PM   #40
Hertzdaddy
Do tell about the Cherokee coils. Wouldn't that be just like using the light duty or 6 cyl coils from our trucks?
Hertzdaddy is offline   Reply With Quote
Old 12-05-2012, 03:06 PM   #41
KQQL IT
At the body shop.
KQQL IT's Avatar
Go into the drage racer part of the board. Look at super73. Post's.
much better explanation than i could do..
Old 12-05-2012, 06:21 PM   #42
shoob
makes sence, the truck was originally a 250ci 3-speed, and somewhere along the lines it had a 350/350 dropped in it. i thought the front felt kinda "spongy".
Old 12-06-2012, 06:58 AM   #43
bk2life
Nothing wrong with big balloon tires or negative camber…
bk2life is offline   Reply With Quote
