Closed Thread
Old 12-06-2012, 08:28 AM   #6601
K98AL
K98AL's Avatar
Re: What did you do to your truck today?
Getting stuff lined up for water heated manifold plate from Stovebolt. Takes a little plumbing....winter is supposed to arrive Sunday afternoon, so I better hurry!
K98AL is offline
Old 12-06-2012, 09:06 AM   #6602
1968C30
1968C30's Avatar
Originally Posted by 88Lt1wagon View Post
I had a Z28 cluster in my '95 wagon, so much better than stock... How does it fit in your C10? Is the LT1 running? Looks like a fun start.
It fits really well. I did this some time ago and dont recall what I did to make it fit. The LT1 is not running and dont have any brakes. I have the impala SS rear end to install. I have all the wiring labeled. Hope to get back to working on it soon...
1968C30 is offline
Old 12-06-2012, 10:21 AM   #6603
kieth
kieth's Avatar
Originally Posted by Vernski View Post
62Barnfind sorry I missed your post the bed liner is from NAPA large spray can. the texture is a little finer than I wanted but looks ok in the end....Vernski
FYI you can buy Duplicolor brand bedliner material by the gallon then roll it on. If you want more texture you can add sand to it. We used it on trailer floors and it worked great. Lots less expensive than paying for rhino liner etc..
kieth is offline
Old 12-06-2012, 01:33 PM   #6604
Pablo22
Finished lowering the 65 yesterday. The rear shocks that came in the kit were too small so I put the originals back on for now. Looks great and the ride isn't bad either.
Pablo22 is offline
Old 12-06-2012, 11:57 PM   #6605
dantimdad
dantimdad's Avatar
Too nasty to do much.
I did go upstairs in the shop and organize parts and inspect to get an idea where I stand.
Really not all that bad. One fender needs a patch, both door bottoms and both doors have about 6 mirror screw holes. The grill support just needs stripping.
Looks like 90% of the work will take place on the cab and the hood.
Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla
Matt. 6:27 "Who of you by worrying can add a single hour to his life?”
http://www.67-72chevytrucks.com/vboa...=507266&page=2
dantimdad is offline
Old 12-07-2012, 07:03 AM   #6606
Hx16457
Hx16457's Avatar
Installed new heater blower motor, had to use a mirror to see the holes.
I did not remove the heater box so lining up the blower mounting holes with the Bo was a bit tricky.
Took about 20 min.
People who make excuses didn't want to do it in the first place!
http://s1326.photobucket.com/albums/...cpZZ1QQtppZZ16
Hx16457 is offline
Old 12-08-2012, 03:36 PM   #6607
dantimdad
dantimdad's Avatar
All the suspension parts are painted!
Will begin assembly after a couple days of cure time.
Pics later today...
Steven
Old 12-08-2012, 04:47 PM   #6608
64shortbox
64shortbox's Avatar
I bought a Gearhead 21 Circut 18 fuse universal wiring harness, wires are hot stamped every 6" and are GM color coded. I haven't started wiring my truck with it yet but it looks like a pretty good piece for the money.
Now I can add my power windows, door locks, electric cooling fan, electric fuel pump etc. and have lots of room left over to add even more accesories. It will sure beat the 6 fuse factory fuse block.
I'm also looking into adding an ignition switch out of a 1962 Pontiac. That way I'll have an acc. switch position and I've always liked that light up ring that surrounded the old Pontiac ignition switches.
64shortbox is offline
Old 12-08-2012, 05:06 PM   #6609
bschoolz1
spent the afternoon rippin out the rotted wood
bschoolz1 is offline
Old 12-08-2012, 07:41 PM   #6610
dantimdad
dantimdad's Avatar
Here's the pic of the last of the suspension parts:
I'm really happy with the way they turned out. Can't wait to assemble the chassis again.
Steven
Old 12-08-2012, 11:29 PM   #6611
198plus
198plus's Avatar
After 10 years, my drive shaft is finally in ..........
198plus is offline
Old 12-09-2012, 04:16 PM   #6612
dantimdad
dantimdad's Avatar
Cleaned the engine 3 times with purple clean, a scrub brush and a pressure washer. That was the nastiest engine I have ever seen!
Also used my autozone card to get a free harmonic balancer puller and got it off.
Finally, I wire wheeled the engine to get it ready for deburring, a good wipedown with brake cleaner and then paint. I want to set the engine and trans before I wrap up the frame in tarps and start on the body.
Steven
Old 12-09-2012, 09:19 PM   #6613
a37lesalle
a37lesalle's Avatar
Finally got the wiring figured out and every needing power has it. Just have to bleed and adjust brakes and should be insured and registered in 2 weeks. Been waiting for that so I can start driving it and start the next project, a 46 Plymouth. It will be reborn with a SBC power plant.
a37lesalle is offline
Old 12-10-2012, 12:43 AM   #6614
shortbed70
shortbed70's Avatar
Filled my antifreeze up after new intake gaskets and ran it for a few to check things out...
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline
Old 12-10-2012, 02:25 PM   #6615
ChuckW
ChuckW's Avatar
Spent the weekend fitting and installing the wood and tubs... So close!!
ChuckW is offline
Old 12-10-2012, 11:58 PM   #6616
1enick72
1enick72's Avatar
Steven
Did you use hammered finish paint? Looks good.
65 short step
edited by staff
1enick72 is offline
Old 12-11-2012, 12:12 AM   #6617
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Finished up my AC/heater hoses for the Vintage Air.
Alan's Classic is offline
Old 12-11-2012, 02:01 AM   #6618
markeb01
Senior Enthusiast
markeb01's Avatar
Beautiful work! That looks really nice.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
markeb01 is offline
Old 12-11-2012, 12:26 PM   #6619
ChuckW
ChuckW's Avatar
For Kevin... "65 Custom" 67 Cadillac "Pinecrest Green"
Cheers!
ChuckW is offline
Old 12-11-2012, 01:18 PM   #6620
65Custom
Cheers!
Thanks for the pic I really like that color
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=366677
I must be
65Custom is offline
Old 12-11-2012, 01:27 PM   #6621
dantimdad
dantimdad's Avatar
Yes, hammered black. 3 coats thinned 25% with acetone shot out of a HF HVLP gun at 30 psi.
Thanks!
Steven
Old 12-12-2012, 12:56 AM   #6622
Alan's Classic
Thanks Mark!!
Old 12-12-2012, 12:05 PM   #6623
jimmydean
jimmydean's Avatar
I have made some serious progress on my center console/shifter setup. I hope to have it finished this weekend and will add pics to my build thread. Should be kinda cool.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline
Old 12-12-2012, 12:12 PM   #6624
dantimdad
dantimdad's Avatar
Might have made a deal for tax time to pickup a 65 swb ss with no engine but very little rot for $750.
I will be using the doors and wheels on my truck and selling the rest. That's the plan but, knowing me, it'll turn into another project.
Steven
Old 12-12-2012, 04:46 PM   #6625
TehNewGuy
TehNewGuy's Avatar
Tore everything out of the cab to wire wheel the corners and get a better look at the rust damage... Exciting...
1966 Chevy C10 LWB Fleet- Project
TehNewGuy is offline
Closed Thread
