Old 12-03-2012, 03:04 AM   #1
lts70
1970 Daily Driver
lts70's Avatar
Sound Deadening like Dynamat
I saw a thread the other night of a guy saleing sound deading with equal preformance a dynamat but with out the name or price. I can not find the thread for the life of me. Can anyone help me out with a link?
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance.
lts70 is online now   Reply With Quote
Old 12-03-2012, 03:11 AM   #2
bugmasta
bugmasta's Avatar
Re: Sound Deadening like Dynamat
Look up raammat
http://www.raamaudio.com/
As good if not better than dynamat. Used it in my latest build and much easier to use. Highly recommend.
68 c20 build: http://67-72chevytrucks.com/vboard/s...d.php?t=358130
Club longbed ...cause girls like'em long!!!!!
bugmasta is offline   Reply With Quote
Old 12-03-2012, 07:14 AM   #3
Crash_OK
Crash_OK's Avatar
Maybe this is what you are looking for..
http://67-72chevytrucks.com/vboard/s...d.php?t=538426
Mark
Crash's 69 4x4 SWB
Crash's Roof over Lake Home
Crash's 1988 Land Cruiser Build
Crash_OK is offline   Reply With Quote
Old 12-03-2012, 08:02 AM   #4
mygmctruck
A lot of guys are using the rubber roofing stuff , it's the same product as Dynomat but just a little thinner and no aluminum surface. Though it's some what thinner , you can double layer it. It's a whole lot cheaper too.
mygmctruck is offline   Reply With Quote
Old 12-03-2012, 08:27 AM   #5
WadmalawJoe
WadmalawJoe's Avatar
I will be doing the roofing product when I do mine. Some Lowes carries it, other than that a roofing store. Its a peel and stick product, as in peel off the paper and it sticks like heck, I have done roofs (houses and commercial buildings) with it. You can get a whole roll for like $50, its 40 inches wide by 50 feet. They also have smaller flashing size rolls that are 9 or 12 inches wide by 50 feet. I think you can get the peel and stick flashing type with aluminum on it. Some areas of the country call it ice and water shield I believe. For you poor souls that live where you get snow build up on your roofs.
I just remembered there is a window wrap product that has aluminum on it. Its for when you are installing a new window in a new house, you line the opening with it before you set the window, and /or put it over the nailing flange of the new window.
Toys/projects
Many toys, not enough time to play!
My youngest son and I picked up a 69 Chevy C-10 on 1/7/22, this is my second 69, it was 10 years ago that I had my other one. So I’m back!!!
WadmalawJoe is offline   Reply With Quote
Old 12-03-2012, 09:08 AM   #6
TobyArnot
Quit if it's not FUN!!!
TobyArnot's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=553612
TobyArnot is offline   Reply With Quote
Old 12-03-2012, 09:22 AM   #7
mygmctruck
Originally Posted by TobyArnot View Post
Ok, I didn't see this thread or at least these posts. The last one I read was he was not going to be able to supply this stuff anymore.
Great now he can.
Old 12-03-2012, 11:21 AM   #8
72BBCK20
Try Fatmat or Fattmat, I got mine from them very happy with the product and much! cheaper that dynamat.
72BBCK20 is offline   Reply With Quote
Old 12-03-2012, 03:09 PM   #9
Fitz
Fatmat is asphalt based and loses adhesion when the panels get cold ( ie winter). Rhinomat and Dynamat are both EDPM rubber and the adhesion is not affected by temperature.
Fitz is offline   Reply With Quote
Old 12-03-2012, 03:19 PM   #10
72BBCK20
No offence but I think its a little colder in Canada, and I have not had any adhesion problems with the Fatmat.
Old 12-03-2012, 03:31 PM   #11
benny70
i used hushmat in my last project, worked great
benny70 is offline   Reply With Quote
Old 12-03-2012, 04:08 PM   #12
tubbedII
needs more $$$
tubbedII's Avatar
Originally Posted by bugmasta View Post
Look up raammat
After A LOT of research, I went with this product. VERY happy with the results and would highly recommend it and will use it for all future projects.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 12-03-2012, 07:26 PM   #13
hfd410
hfd410's Avatar
I used FatMat. Easy to work with, seems like good stuff
hfd410 is offline   Reply With Quote
Old 12-03-2012, 08:02 PM   #14
BiggSixx1970
I was walking through Westlake/Ace hardware the other day looking for some plastic tubing for an aquarium and walked by the insulation and saw a roll of some stuff that looked VERY similar to Dynamat, now I doubt that it's the same stuff, but insulation is insulation right? It doesn't have adhesive on one side, buuuut I imagine with some spray on adhesive you can make it work. This is an option I am considering when it comes time to re-upholster my truck
Who cares if it's not dynamat or some other name brand sound dedener? If it works, it's going to be under carpet anyways
1970 C20, SM465, Eaton Ho52, HD coils, NO PB/PS/AC, 250 I6, Wood bed. All original minus a tune up!
http://67-72chevytrucks.com/vboard/s...d.php?t=545486
Gentlemen wear a bow tie.
BiggSixx1970 is offline   Reply With Quote
Old 12-03-2012, 11:11 PM   #15
70cst
70cst's Avatar
I used B Quite with great success
http://www.b-quiet.com/
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 12-07-2012, 07:32 PM   #16
MidLifer
MidLifer's Avatar
I went through all of this research this summer when I did my cab - there are as many opinions out there on this stuff as there are truck owners, it seems....anyway, the first thing I'll say is that I used Raammat and was very happy with it. Secondly, and I'm going to shout here, YOU DON"T NEED TO COVER EVERY SQUARE INCH WITH A PRODUCT LIKE THIS. The function of the metal/adhesive products like Raammast is to dampen vibration, and you only need to cover 25-50% of the sheet metal to accomplish that. However, to truly quiet your interior, a product like this isn't enough.
You should put down a mat product like this first, then a layer of isolating foam (I used Ensolite, available from Raam Audio), and lastly, mass-loaded vinyl, which is a heavy product that is what actually keeps sound from passing into your truck. This is the stuff they use when they build recording studios. It's not the easiest stuff to work with, mainly because of the weight, but once you get it in it really deadens sound.
MLV is hard to source, again because of the weight the shipping can be costly. Insulation supply houses often carry it. It comes in rolls that are 4'x20', which is enough to do 2 truck cabs.
Pics of my interior project can be seen here, with all 3 steps discussed above:
https://picasaweb.google.com/1102505...51425959656194
Good luck!
MidLifer is offline   Reply With Quote
Old 12-07-2012, 10:59 PM   #17
rico7769
Hybrid67
rico7769's Avatar
fatmat is my choice, but I've used the stuff from lowes that's really designed for ductwork and comes with the aluminum backing. Cost about 35.00
Keep em' Running!
All show.....no go
rico7769 is offline   Reply With Quote
Old 12-07-2012, 11:03 PM   #18
firedog
firedog's Avatar
i also had great results with the stuff from lowes very easy to work the contours and easy to cut with a knife no adhesion issues.
*SOLD*
1968 Chevy SWB Fleet
350/350 combo
Tach/tilt/buddy buckets
Bagged/18" Wheels
Black on Black
Project "Pandemic" the Farm Rat
1927 Chevy Capitol Truck Rat rod
'30 Model A Frame
Dual Carb 5.3 LS
http://www.67-72chevytrucks.com/vboa...d.php?t=804162
2007 GMC 4 DOOR 2WD
BUILT 5.3 STAGE 3 CAM 93 TUNE
LIFTED 22X12 WHEELS 33" TIRES
2023 Jeep RENEGADE
Wifes ride
firedog is offline   Reply With Quote
