#76 |
Re: My own build thread
Great work man!! Truck is gonna be sick. Love the renderings.
#77 | |
#78 |
#79 |
chevy only
![]() Join Date: Sep 2006
congrats trucks looking sic..... and congrats on the kids wow!
CHEVY ONLY... Nothin Else ! |
#80 |
Nice progress. I went to Disneyland last week too. Its so expensive!
Posted via Mobile Device |
#81 |
No congradulations needed sir, actually I'm willing to pay people to take my kids.... They don't clean up, they whine a lot, they are expensive but hey, they are all good looking because of their Mom
![]() Thanks for all the nice comments everyone, I hope it turns out half as nice as the rendering. I'm starting to think I'm never going to get this damn thing finished... I spent 5-6 hours making the rear shock mount brackets because I got the bright idea of just modifying a set of stock front shocks and making them work for the rear... Well, they work but holy crap was it a PITA to compress the shocks, hold the tabs, weld and try to make sure everything staid in the correct place all by myself... I did my fair share of cussing and acting like a child but I got it all done... The reason it took me so long was that I used the top bolt setup from the front shock "the bolt with the long stud that comes with the shock" and used that for the bottom and welded it to my 4 link bracket to use for the bottom shock mount. What I didn't realize at the time "like an idiot" was that the bottom hole in the shock isn't the same diameter as the top, it has a roll pin in a rubber grommet. So... no big deal I thought I'd just use my press and push the roll pin out and bolt it in... WRONG! Once I got the stupid roll pin out of the grommet the hole was much too small for the bolt. So I spent about an hour with a high speed grinder trying to make the hole large enough because I didn't have a big enough drill bit. It actually turned out prety well but it took me a long time. There has to be a shock out there that will fit without any modification but I had already bought these shocks and didn't realize it would take this long to make these work. But now everything is welded in and fits pretty good. Now I need to figure out how to mount this gas tank. ![]() Here are the tabs I made, I didn't take a good picture of how I did the bottom. The good news is that both front and rear shocks are done. |
#82 |
Ok, another update. Last night I finished installing the rear shocks and installed my Capt Fab steering box adapter "works great BTW". Tonight I have to finish welding up the frame because I had to notch it because the steering linkage was hitting a little then I can hopefully paint the frame, finally...
#83 |
Just here to tinker
![]() Join Date: Jun 2008
Just read through this. that is going to be one killer truck. I really dig the paint scheme.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
#84 | |
Ok, so I got a little done this weekend. Not as much as I would liked but progress is progress right! I installed my "new" tilt wheel column, I need to go get some universals and a hime joint today so I can finish the steering linkage but here is the column. Obviously I need to change the steering wheel but you get the idea. ![]() I also installed the gas tank, I can't believe these damn things come with no instructions... I ended up moving the rear cross member back, welding in some square stock in the front to make a box so the flanges on the tank hold it up. Then I took one of the straps and welded it in front and bolted it to the back. I left the strap about an inch short so when I bolt it down tight it hold it from moving. There's probably better ways to do it but I didn't want to put the tank any lower for fear of scraping it on the ground when the bags are down. ![]() I also finished welded up the portions I cut out for clearance for the steering linkage. Curving 3/16 plate steel is not easy... A vice and a Big ass hammer work well.... lol ![]() ![]() Here's the top of one of the plates I welded in ![]() Oh ya, I also finished striping the whole firewall and windshield channel, makes a bit of mess.... haha! ![]() |
#85 |
I looked the same after stripping the rear of my truck yesterday. Damn man, lots of great work! Pulling for you!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
#86 |
I started taking the dash apart yesterday and finally took down this awesome custom corderoy headliner that was help up by.... wait... yep those are 70's dresser hardware and plastic mirror brackets holding it up! lmao!
![]() ![]() Hopefully I can get the dash and everything sanded as well as the 800 holes the PO drilled in everything by this weekend and get the inside of the cab primed. If I can accomplish all of that I will be pretty happy. |
#87 |
Good luck buddy, I know I was pretty happy to get all that done as well.
Now I am at the dash and below at this point now.
Michael McMurphy My 66 Stepside My 64 Tow Truck My 66 Tempest Table Of Contents Added to Page1 |
#88 |
Got the steering completed. I thought I was going to have to use a hime joint but after putting everything together it turns really well with no problems
![]() ![]() Posted via Mobile Device |
#89 | |
I just finished doing the same thing a couple of weeks ago and had to use three knuckle joints. I noticed you welded the first joint on the shaft closest the steering shaft lower bearing. How are you going to adjust/align your steering wheel without adjustment bolts after wheel alignment? |
#90 | |
Actually the more I think about this I don't know if I'm following you. The only way I would think you could adjust this would be to slot some holes and I'm not sure if I would feel to safe doing that. A stock steering shaft doesn't have adjustment. I've built a few hot rods and I've always done it this way and haven't had any problems. As long as you make sure your seat is in a good spot then the seat adjusts rather than the steering shaft. Posted via Mobile Device Last edited by zippeay; 12-08-2012 at 11:34 AM. |
#91 | |
I'm really enjoying your build thread. I can tell you have really worked your butt off on this project and you're doing a great job. You take chances that most wouldn't dare and if you make a mistake, you fix it, and move forward. That's tough to do raising 6 children! ![]() |
#92 | |
Wow, thank you for the compliments! There two things I really don't mess with too much and that is brakes and steering. I had an old friend tell me to never mess around with either, over engineer them and never modify those two things but if you have to use really good parts. Everything else is fair game. I've always tried to follow that because it makes a lot of sense for safety purposes. I honestly wasn't sure how many people liked my build on here because I'm more into traditional hot rod style stuff than most people seem to be on here but I'm glad you like it. My intention of this build was to build it really nice but still drivable and use as many stock parts as I could instead of buying tubular suspension. I did that for two reasons, one is because I couldn't afford those things "which in hind site I've still spent a lot and had to spend a ton of time fabricating things" but I like fabricating so I don't see that as a negative. For two I want to show a complete build that other people could follow and hopefully use as a guide for their build instead of searching a bunch of different threads to use as a guide. I know a lot of people would have done things different but hopefully someone finds this thread useful. Again I'm glad you like it, thanks! Posted via Mobile Device |
#93 |
Well, here's there latest. I tore the whole cab apart and welded up probably 80 holes the PO decided to drill everywhere but I forgot pics of that. My Old man helped me hang the fenders last night and mock up the front one last time before paint. We still nee to finish the body work on the passengers door and a few spots on the cab that I patched. Then she should be ready for paint! I keep saying that but hopefully I'm right this time. I also broke my damn wedding ring last night
![]() Anyway here are the pics. ![]() ![]() My old man, he's awesome at body work! ![]() Posted via Mobile Device |
#94 |
He don't look like an old man!
#95 |
Only old people say that! Haha!
Put the bed on for the last time to figure out the mounting and also figure out the bumper brackets. ![]() Getting pretty excited now. Can't wait to squirt the paint on! ![]() Wheels tuck really nice! ![]() Posted via Mobile Device |
#96 |
#97 |
#98 |
Oh geez, you're still in diapers! The truck is looking great...keep it up! I'm on hiatus until after xmas. Then, I'm going to z'frame, install my T5, and get to work on the rear. Hopefully driving by summer.
#99 |
Nice, good luck! I was supposed to be done last summer haha
#100 |
haha same story on my truck!!! keep up the good work man!!!
![]() bagged 66 longbed build http://67-72chevytrucks.com/vboard/s...d.php?t=449548 my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918 |
