10-23-2003, 04:37 AM | #1 |
Courtesy Light Bulb Question?
Has anyone come across a brighter bulb for the courtesy light? If so, do you have a part number? Thanks
Just sitting here contemplating contemplation. |
10-24-2003, 12:04 AM | #2 |
Sisyphus was my mentor!
I second that - I'd love a brighter interior light BUT my only fear is brighter=more heat & that may melt the lens.
passthebuck #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
10-25-2003, 07:22 AM | #3 |
68 suburban.... if you are referring to the dome lamp ( center cab; on cab inside roof above the seat back) the original lamp was a # 211. This lamp was a T-3 bulb ( looks like an oversized fuse).amps is .97 ; 12 C.P. Looking thru my Philips lighting specs; I find that a # 577; 1.4 amps; 21C.P is available.....This lamp should give almost double the light output at an increase of .43 amps....I would take the stock # 211 lamp with you to compare to the # 577 to be sure the diameter of the lamp will fit the socket clips........Jim
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal). |
10-25-2003, 08:31 AM | #4 |
Jim, thanks for the info
