Old 12-07-2012, 03:40 PM   #1
gafiredog
rear gears
does anyone have an idea what the gear ratio would be in my 75 c-10, 250-6 cyl. 350 turbo. I can't find a tag on it, or a stamp in the housing. maybe I'm not looking in the right place, Anyway, It sounds like the rods are gonna come out at about 60 mph., and the best it will do on mileage is about 11-12 mpg.
Art
1975 c-10 stepper
1978 single cab dually
1987 crewcab dually
1986 crewcab single wheel
1948 anglia- (the dixie twister super gas)
gafiredog is offline   Reply With Quote
Old 12-07-2012, 03:45 PM   #2
mooseknuckles
mooseknuckles's Avatar
Re: rear gears
thats prob normal mileage!...lol......not 100% but I thought the 6cyl's had 3:73's?....find a 700r4 and some 3:42's...what size are your tires?
mooseknuckles is offline   Reply With Quote
Old 12-07-2012, 03:59 PM   #3
gafiredog
Re: rear gears
235/75/15
Art
1975 c-10 stepper
1987 crewcab dually
Old 12-07-2012, 04:13 PM   #4
mooseknuckles
Re: rear gears
Originally Posted by gafiredog View Post
235/75/15
think thats like a 29" tire, so you prob cant go much bigger...
Old 12-07-2012, 10:45 PM   #5
wilkin250r
wilkin250r's Avatar
Re: rear gears
When you say "It sounds like the rods are gonna come out at about 60 mph", I'm assuming you mean it's revving really high? Sounds like it's probably 4.10 gears then.
A lot of us are getting 11-12mpg, but we're running bigger engines. I would think a 6-cylinder would get better than that, and the gears might be the culprit.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 12-08-2012, 09:02 AM   #6
Keith Seymore
Keith Seymore's Avatar
Re: rear gears
Here's the info packet for a '75 Chevy pickup as found in the GM Heritage Center archive:
http://www.gmheritagecenter.com/gm-h...olet-Truck.pdf
Per the powertrain chart on page 28 base axle is a 3.73 with an optional 4.11.
Of course, anything could be in there now so the only sure way would be to do the driveshaft/tire trick or to pull the cover and count teeth.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 12-08-2012, 09:58 AM   #7
gafiredog
Re: rear gears
Thanks for the help guys, I have had people tell me they had the same or close to what mine has, and they put in a 308, or 2 something gears, and mileage improved to around 17-20 mpg. this sounds like they are full of s^%t, or is that possible to gain that much mpg?
Art
1975 c-10 stepper
1987 crewcab dually
Old 12-08-2012, 01:52 PM   #8
LONGHAIR
Re: rear gears
Gearing has a lot to do with the intended use of the truck. If you are a highway driver that sees the majority of driving at 75+ MPH, a higher gear will help you out. But....in the city, it will be a complete dud. Not only sluggish to drive, but mileage will suffer because it requires more throttle to move it around.
Those high gears (308, 273, etc) also are not so friendly to carburetors. Running down the road at too low of an RPM gets them into all kinds of metering issues. Injection handles this better, but it is still sub-par. You really need to be geared to hit your engine's "sweet spot" and your most used speed. That ideal RPM is Dependant on the engine's size compared to the truck, the cam, etc....
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
