Old 10-24-2003, 02:02 PM   #1
oteixeira
Parts for sale! PS. Auto non tilt column, etc...
Hi all,
Have some parts I would like to move:
I have:
- P/S pump, with all sb brackets, and pully. $60 obo
- Set of 6 lug rally rims, with trim rings but only two caps (4x4 type), with mounted Bridgestone Deuler tires with less then 5000 miles - $200
- Complete 70 non A/C cab, with little rust on outer rockers, cab corners, and two small rot holes at the bottom of the side of the cowl. $150
- 2 x used HEI distributers, unknown condition, but they seem to function normally, just haven't used them $15 each
- Quadrajet for a '70 sb truck, needs rebuild $25
- Drivers side saddle tank, this is the one WITHOUT the sending unit $30
- Cowl off of a '70 decent shape $25
- Imperial (branded on the switch end) 3 tank switch mounted in cab floor on drivers side, seems locked up, but may be rebuildable $15
- Used Edelbrock torker manifold. Could use a beed blasting $25
- Holly 600CFM carb, needs rebuild $25
- 69/70 Chevy Grill (Complete) - Outer grill has all the black faded off, but is in nice shape. Inner grill has a few broken spots, will include turn signal setup as well as headlight trim (the headlight trim has some surface rust) - $100
- 69/70 hood - $25, come get it.
- Drivers side inner fender, good shape, no rot, could use sanding and paint - $25
- 69/70 Front Fenders (both), they both need the lower patch panels as far as I can tell, $40 for both of them.
I am not willing to ship the rims/tires, the cab or other LARGE parts. UPDATED, lower prices.....
Thanks,
Orlando
70 C-20 Custom Camper
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=300251
oteixeira is offline   Reply With Quote
Old 10-24-2003, 02:13 PM   #2
mocwon
Keep On Truckin'
mocwon's Avatar
I'll buy the intake. Ley me know shipping to business address in zip code 78744 (Austin, TX).
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 10-25-2003, 08:46 AM   #3
72shadetree
KEEP ON TRUCKING
72shadetree's Avatar
how much shipping for the x member and column to 24055 where is wilson im in martinsville va thx
72 cheyenne 2wd lwb
71 k20 sons
bassett va
72shadetree is offline   Reply With Quote
Old 10-25-2003, 06:05 PM   #4
69&72Bowties
steering column
Auto stearing column, all that is wrong is the plastic part from the indicator is missing $30 obo
Do you have all the linkage for an automatic also?
Bryan@ideamill.net
71 Chevy Custom 20 Suburban
69 Chevy Camaro
69&72Bowties is offline   Reply With Quote
Old 10-25-2003, 11:02 PM   #5
oteixeira
Anwsers
72shadetree,
Wilson is right off of I-95, exit 121. I would have to figure shipping, I will PM you with them amount unless you tell me you are going to come pick them up here.
69&72Bowties,
I am sorry, no auto linkage....
Orlando
Old 10-26-2003, 12:07 AM   #6
72shadetree
KEEP ON TRUCKING
let me know on shipping thats a good distance from here
72 cheyenne 2wd lwb
71 k20 sons
bassett va
Old 10-26-2003, 11:17 AM   #7
oteixeira
Postage amounts
Hey,
Mocwon-The intake shipped to your door would be:
15.31 normal
19.75 Priority
So total cost would be either 40.31 or 44.75
72shadetree:
the two parts (column and crossmember) shipped to your door:
15.29 normal
25.95 priority (we are so close I see no reason to pick this)
So total cost would be either 70.29 or 80.95
Thanks guys...If you want them let me know, and I will pm you an address to send a money order to.
Orlando
Old 10-26-2003, 03:16 PM   #8
69C10Atl
Trying to stick with it
69C10Atl's Avatar
IS this the ps bracket you have, if so what would shipping be to 30360
69 Chevy C10 LWB somewhere in the pile of parts in my garage.
01 Cadillac STS as daily driver
69C10Atl is offline   Reply With Quote
Old 10-26-2003, 04:09 PM   #9
72shadetree
KEEP ON TRUCKING
thanks sent you a pm consider the column and x member sold
72 cheyenne 2wd lwb
71 k20 sons
bassett va
Old 10-26-2003, 06:57 PM   #10
oteixeira
P/S stuff
69C10Atl,
Yup, thats it. Plus the pump and pully. It will be $12 to ship. So that is $87 if you want it, pm me for my addy if you want it.
Orlando
Old 10-26-2003, 07:04 PM   #11
BigBlockBurris
BigBlockBurris's Avatar
PM sent!
PM Sent!!!!
BigBlockBurris is offline   Reply With Quote
Old 10-27-2003, 12:00 AM   #12
oteixeira
Mail is full
BigBlockBurris,
Tried to PM you back but your box is full......
Old 10-27-2003, 12:16 AM   #13
BigBlockBurris
PM box
Sorry about that. It's empty now. Thanks
BBB
Old 10-27-2003, 11:09 AM   #14
oteixeira
BBB, you now have a PM
Orlando
Old 10-28-2003, 10:23 AM   #15
oteixeira
Bump - added stuff & lowered prices
BUMP
Old 10-28-2003, 10:28 AM   #16
72shadetree
KEEP ON TRUCKING
sent mo yesterday for the other stuff
would you ship inner fender if so how much 24055
72 cheyenne 2wd lwb
71 k20 sons
bassett va
Old 10-28-2003, 11:09 AM   #17
oteixeira
72,
Not sure it would be woth shipping to you, It is big, and odd sized, and may almost double in cost if I were to ship it. Sounds like you just need to make a weekend trip to my place!
Orlando
Old 10-28-2003, 01:45 PM   #18
72shadetree
KEEP ON TRUCKING
thanks pm sent
72 cheyenne 2wd lwb
71 k20 sons
bassett va
Old 10-28-2003, 05:58 PM   #19
bryondillon
Do you have a picture of the outer grill?
Someday I might get my truck running again =(
bryondillon is offline   Reply With Quote
Old 10-29-2003, 12:25 AM   #20
oteixeira
Pictures
Bryon,
With the time change and all the rain I have been having a hard time taking pics, but I will see what I can do for you.
Orlando
Old 10-29-2003, 02:01 PM   #21
oteixeira
Old 11-02-2003, 11:29 AM   #22
oteixeira
Pics of the grill
If they dont show up follow these links:
http://www.geocities.com/oandcteixeira/DCP_0010.JPG
http://www.geocities.com/oandcteixeira/DCP_0011.JPG
http://www.geocities.com/oandcteixeira/DCP_0012.JPG
http://www.geocities.com/oandcteixeira/DCP_0013.JPG
http://www.geocities.com/oandcteixeira/DCP_0014.JPG
http://www.geocities.com/oandcteixeira/DCP_0015.JPG
http://www.geocities.com/oandcteixeira/DCP_0016.JPG
Orlando
