Por 15 Engine Enamel
first off i'm not bashing all POR15 products
i'm in the middle of an engine build and decided to use this engine enamel what a nightmare it doesn't cover worth a damn takes forever to dry completely, it's probably the worst brush on engine enamel i've ever used !!! thickens on the brush as you're working and if you thin it then its run city and it just doesn't cover i just finished a second coat and will need at least another one to fully cover !!! why didn't i stay with the spray on stuff from eastwood??? sorry about ranting but i'm just so frustrated after all the prep work and dollars i've got into this and now it's coming out like crap it's really looking like i'll end up stripping this crap off and going back yo yhe dependable eastwood stuff THIS SUCKS
Blazerless:-(
That does suck! Hopefully the 3rd coat covers and you don't have to strip it. I am glad that people post the good and the bad things about products they have used...I don't consider that bashing. I am glad to get the info. so I don't have to make the same mistakes. Thanks and good luck!
Diane |
Keepin an eye out
I used in on a MGB block and thought it was awesome, dried super hard
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
Cantankerous Geezer
I used on the 235 for my 52. It went on fine, thick, but leveled out nice and took forever to dry. Then I found it wasn't the right flavor of Chevy Blue, and sprayed over it with Plasti-cote.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
![]() Join Date: Apr 2000
don`t you use an hardner with that???
my nefew is doing a 4 wheeler frame chevy orange,and the dealer told him to paint it with the grey por-15 then use the orange on it,and he said you have to use the por-15 hardner with it... good luck jamie
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
no hardener involved it's just regular engine enamel not their epoxy stuff
![]() Join Date: Dec 1999
I've used the stuff with pretty good results. It does take forever to dry and it is sticky when you put it on. POR claims it is because it has a very high concentration of solids. I thought it was like old fashioned paint. The Chevy orange sure looks nice and glossy. I think I put 4 coats on ... with a new brush for each coat.
68C10 1968 C10 SWB No Options but 40K original miles 1967 K20 LWB 283 4-speed South Plainfield, NJ |
Merciless Butcher
I wonder how well that POR will let heat dissapate from the engine block. Seems to me if it's put on thick and it's a high solids paint, it would retain alot of unwanted heat....Just a thought?? would like to hear what other people think. When I was a kid, my buddies dad raced cars at bonneville. He always painted his engines flat black. Said it was the best paint to use if you wanted to get rid of unwanted heat. Chromed oil pans also do a good job of retaining heat..........Greg
Your Bought And Sold....I Got Your Soul! |
![]() Join Date: Aug 2001
I used the stuff on my new block. It looks great. Took forever to dry was a pain in the but to brush. I did clean the entire block with Xylene. It did not stick to the oil pan or the timing chain cover as well as it did the block. I will have pix later in the week.
Thats the Hillbilly way
Looks like this is not a product to try to brush on the engine while it is still in the truck .
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
would not try it again with a brush tomorrow i'll be giving it it's 4'th coat that should pretty well finish it up
i couldnt imagine trying to use this stuff while the engine is in a vehicle the finish is getting better(shiney) but the stuff has a real tendency to run and sag, i just didn't imagine that i'd have to tie up the shop for close to a week just to paint a longblock, when i can do the same job with quality spray enamels in just a couple of hours
