Old 12-08-2012, 01:34 PM   #1
Mister-B
Location of windshield washer pump
My pump is bad. Looks like it goes under the dash, but does anyone know exactly where? My local junk yard has two of these trucks, so I want to see if I can find this part under the dash, but don't know where to look, or if it is hard to remove?
Mister-B is offline   Reply With Quote
Old 12-08-2012, 01:43 PM   #2
FirstOwner69
FirstOwner69's Avatar
Re: Location of windshield washer pump
It's attached to the wiper motor which is to the upper right on the inner cowl behind the instrument cluster. It's harder to access if you have A/C. Easiest to get at if you pull the cluster.
FirstOwner69 is offline   Reply With Quote
Old 12-08-2012, 01:46 PM   #3
Mister-B
Thanks so much. That helps
Old 12-08-2012, 01:50 PM   #4
Sillyoldman
#16876
Sillyoldman's Avatar
All you need is long arms, flexibility, time and patience.
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 12-08-2012, 02:08 PM   #5
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Here/s a couple of pics of the pump.
Name:  wiper motor 2.JPG
Name:  wiper motor.JPG
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 12-08-2012, 02:25 PM   #6
Mister-B
Thanks for the additional info, guys. That helps
Old 12-08-2012, 05:10 PM   #7
Mister-B
Ok guys. I got it out of the junker and bought it. It was 6 bucks, is off a 71, and looks brand new. As an FYI, removing the instrument cluster doesn't help. I did that, since it was a junker, but it didn't help. It's actually closer to the radio. One junker had a radio, and I had a hard time getting it out and gave up. Went to another junker that had the radio removed, and it was cake to get to it
Old 12-08-2012, 06:12 PM   #8
truckster
truckster's Avatar
Here's another option you might want to consider:
I took the tank with the electric pump from an S-10. I wired it into my washer switch so it works with the center button, but it's easy to get to, has great pressure, and I can replace the whole thing for less than $10 and about 5 minutes of work if I need to.
I mounted it in the same location as the stock pump.
truckster is offline   Reply With Quote
Old 12-08-2012, 06:18 PM   #9
MidLifer
MidLifer's Avatar
Truckster, thanks for the tip. I've owned my 71 going on 2 years, have tried to replace the mechanical pump twice now, and still can't get it to work. I'm gonna try your fix!
MidLifer is offline   Reply With Quote
Old 12-08-2012, 06:23 PM   #10
Malamute
Malamute's Avatar
Make sure it's not the lines that are plugged. Mine sat outside at the previous owners house and they were plugged when I bought it. I'd hate to see you pull things if you don't have to.
Malamute is offline   Reply With Quote
Old 12-08-2012, 07:12 PM   #11
MidLifer
MidLifer's Avatar
Ya, did that already. Thanks.
Old 12-08-2012, 07:30 PM   #12
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Same location as the stock washer reservoir, right? Not pump... ?
Great tip btw.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 12-08-2012, 07:54 PM   #13
truckster
truckster's Avatar
Yeah, sorry. I meant the reservoir. The pump on the S-10 washer bottle is on the bottom of the bottle.
I also wired the switch using spade connectors so I can go back to stock if I want to.
Old 12-08-2012, 08:32 PM   #14
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
getting it out and gave up. Went to another junker that had the radio removed, and it was cake to get to itPosted via Mobile Device
Glad it was "cake" for you. On my truck, with the radio out (actually, the back of the radio cut off...but that's another story), AND the instrument cluster/bezel out, steering wheel off, etc. It was a PIA.
I was a 66 year old pretzel under the dash (bucket seats IN, unfortunately).
So...I didn't wanna do it again. I left the broken pump on, IIRC, and put a $16 electric pump on top of it, replaced the hoses because I wanted to, hooked up the electrics from stock to the stuff supplied
in the Napa kit.....tested it for leaks. Tested it again. Closed it up. It's not stock. But some things are simply better than stock.
Unless someone with a clip board is climbing around under my dash (Hardy-har-har), I'd rather have it work than have it factory.
Of course, YMMV...As it should with all of us.
Here's the rez. Ran the ww supply hose behind the fender.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
Old 12-08-2012, 10:40 PM   #15
ole dollor
ole dollor's Avatar
never had any luck repairing the factory windshield pump, they just don't seem to hold up for very long, i always just add one under the hood and fix the problem....works good for me.
ole dollor is offline   Reply With Quote
Old 12-08-2012, 11:01 PM   #16
Mister-B
Oh great. That hassle, and it might not even work or hold up...
Old 12-08-2012, 11:19 PM   #17
magwakeenercew2jh
I followed the Member's advice and did this with ease....
Here ya go...Don't look back!
http://67-72chevytrucks.com/vboard/s...d.php?t=509404
This is the part that comes up now. I'm sure it's a perfect replacement....
http://www.napaonline.com/Catalog/Ca...300_0000999999
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 12-08-2012, 11:26 PM   #18
oklalawnboy
oklalawnboy's Avatar
Never had luck with used pumps. This last round, I bought a new one from Classic in Mo. Works great and has that wonderful "Clack" sound when she's a pumpin. Did I mention, I love my ole truck....
72 Cheyenne super 10
08 3500 HD 4dr dually
12 ford flex (wifes ride)
76 Monte Carlo
83 Chevy short wide Silverado
96 Mazda Miata, 2000 Allegro Bus
oklalawnboy is offline   Reply With Quote
Old 12-09-2012, 12:45 AM   #19
eagleuh1
eagleuh1's Avatar
I bought one at O'Reillys. looks just like the original. Its just the pump part inside the cab. Think it was like $13.
eagleuh1 is offline   Reply With Quote
Old 12-09-2012, 10:54 AM   #20
bignbad
bignbad's Avatar
I rebuilt my pump works like new but it was a pain to get too that was like 7 yrs ago and still going strong.
'72 chevy k20
'06 H-D Springer softail
http://www.bluemooncruisers.com/
http://www.enginecycle.com/
~Eric
bignbad is offline   Reply With Quote
Old 12-09-2012, 01:22 PM   #21
dirtwork
Which generation s10 did you get the bottle from? 80's 90's? or does it not matter because they are all the same?
dirtwork is offline   Reply With Quote
Old 12-09-2012, 06:44 PM   #22
truckster
truckster's Avatar
I think it was a 90s, but I'm not 100% sure. I was looking more at the condition of the washer bottle. I think either would work.
I can take pics tomorrow if that will help.
Old 12-09-2012, 09:52 PM   #23
WadmalawJoe
WadmalawJoe's Avatar
Yes please post some pics! I am interested as well.
Toys/projects
Many toys, not enough time to play!
My youngest son and I picked up a 69 Chevy C-10 on 1/7/22, this is my second 69, it was 10 years ago that I had my other one. So I’m back!!!
WadmalawJoe is offline   Reply With Quote
Old 12-09-2012, 11:05 PM   #24
ole dollor
ole dollor's Avatar
the one from LMC is about $28.00 it works good, just need to beef up the bracket a little.
