Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 10-18-2012, 11:49 PM   #151
pickup67man
pickup67man's Avatar
Re: Project Family Hauler
Originally Posted by Dieselwrencher View Post
Man oh man you are getting this unit done. I'm debating making a crew cab again, so keep up the work to motivate me. Haha
I took almost 2 years off. The hinge problem slowed me down as much as the rain. I ran out of excuses so I started working on it again. Hopefully I can do more this weekend around pumpkin projects.
Travis
2005 K2500 Duramax (hauls the junk home)
1967 Chev C10 (hauls a$$)
1970 Suburban (Yukon XL 4 door)
1968 GMC 3/4 ton (sheetmetal only, chassis gone)
2005 Malibu (wife's car, still a Chevy)
New Home for Chevys (Moved in and working)
pickup67man is offline   Reply With Quote
Old 10-21-2012, 10:06 PM   #152
pickup67man
Well I got some more done this weekend. Finished filling in all the gaps on the hinge side of the door jamb.
Also took the door skin on and off too many times to count.
Then I had to get the door lock linkage hooked up. The rod had to clear the window channel to I made a new one.
And I filled in the rest of the holes on the latch side of the door.
Latches and locks now.
Travis
Old 10-27-2012, 09:44 PM   #153
pickup67man
Finished grinding the inside of the door and hopefully done welding on the lower inside part also. POR15 the inside of the door. Maybe that means I'm almost ready to close up the work area and the skin will stay on. Maybe.
This is the hinge support from the donor truck. It should stabilize the hinge mounts.
Looks better to hide the rusty colors.
Travis
Old 11-04-2012, 10:13 PM   #154
pickup67man
Finished up rewelding the window frame in what I HOPE is the final position.
Then I worked over the door skin so it fits the frame good. The gap for the window is 1" on all my other doors so that was the number I had to get when the skin fit right. I'm there. Also with all my cutting the drain holes at the bottom of the door disappeared so I made new ones.
Then I started to finish the rocker panels. I started with a drivers side rocker for the rear door. Not much fit right. They aren't cut for a B pillar and the curve is wrong. Then I had to join it to the front rocker to make it flow. Cut, cut, cut. Weld weld weld. It is now one rocker that runs like a uni-brow. When its done I will plug weld it to look like its stamped.
Travis
Old 11-06-2012, 01:31 AM   #155
68 TT
Still plays with trucks
68 TT's Avatar
Nice to see you back at it. Keep it up.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
Old 11-07-2012, 12:36 AM   #156
pickup67man
Glad to be back at it. Hope no one gave up on me.
Travis
Old 11-07-2012, 04:57 PM   #157
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Great work! It's really coming together now!
Ryan
1969 Chevy milk truck
Old 11-11-2012, 08:58 PM   #158
pickup67man
Think I got the rocker panels mostly done this weekend.
One giant one now.
Lots of grinding to get this part to look good. Also found all the curves in the rocker panels. They curve in at the front AND back. Had to cut and massage the part that connects them. It was in almost 1/4" from where the rockers are. I think I need to go to massage school for metal. I'm really slow at all this.
After I got it fit and ground down I remembered since the rear door is suicide I need to have the rubber bumper up front. So I matched the one for the front door.
Now that the door is fitting good I can maybe move forward again.
Travis
Old 11-12-2012, 12:23 AM   #159
jbclassix
Junk Yartist
jbclassix's Avatar
Lookin good man! I'm jealous!
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 11-12-2012, 01:58 AM   #160
pickup67man
Nothing to be jealous about yet. I'm still moving at a snails pace. With the cold wet weather up here I'm glad to have my new garage, but I think I need an exhaust fan to clean all the welding and grinding smoke and dust.
Travis
Old 11-18-2012, 08:21 PM   #161
pickup67man
Only got one day to work on the suburban this weekend. And got a late start, not a lot of energy today. So I didn't get too much done.
Are they ever going to stamp replacement rocker panels that fit correct. I know mine has been modified a lot but I still had to fix the part under the front corner of the front door. If I didn't do this the corner of the door would hit the rocker panel.
Then I had to finish up where I cut the top to fit better. I got so used to seeing it the way it was I almost didn't notice it wasn't finished.
Then I decided to grind more welds on the B pillar. I have put off this part for nearly 3 years. Don't know why, its not any worse that everything else I've been grinding.
Travis
Old 11-18-2012, 08:40 PM   #162
VA72C10
VA72C10
VA72C10's Avatar
Keep at it! Always good to make some progress....I'm headed out to my garage now
On the rockers, I've had aftermarket ones fit perfect w/ no mods needed and the same brand rocker need a lot of work to fit the next truck...I think it's a lot to do with how our trucks were built in the first place...not much QC....
On my shop truck the passenger rocker is factory and the door closes perfect and has great gaps...but every time I shut the door there is a little streak of rust from where it actually hits the painted rocker...the bottom of the door is rusty but not out of shape so just the rust scale makes it hit the rocker....showing how tight it was from the factory...
Old 11-18-2012, 11:49 PM   #163
pickup67man
Wow, late night working in the garage. It was almost 5 PM here when you posted. At 8 PM I wouldn't be motivated to get dirty unless I was getting close to a deadline.
Travis
Old 11-18-2012, 11:59 PM   #164
VA72C10
VA72C10
VA72C10's Avatar
Just cleaning up some parts tonight...my wife and girls were at a baby shower and the race and games I watched were over
Old 11-19-2012, 01:16 PM   #165
Frizzle Fry
Frizzle Fry's Avatar
Great progress!
Frizzle Fry is offline   Reply With Quote
Old 11-19-2012, 01:30 PM   #166
67cheby
67cheby
67cheby's Avatar
looking good !
67cheby is offline   Reply With Quote
Old 11-19-2012, 09:53 PM   #167
Dieselwrencher
Great work! The rocker is looking awesome!
Ryan
Old 11-20-2012, 12:58 AM   #168
pickup67man
Originally Posted by Frizzle Fry View Post
Great progress!
Originally Posted by 67cheby View Post
looking good !
Thanks. It makes me feel good when I get compliments from guys with awesome trucks.
Need to buy some more POR15 for the backside of the rocker and inside of the door skin then I can close up some stuff
Travis
Old 11-25-2012, 09:13 PM   #169
pickup67man
I spent this weekend with so many excuses that I didn't get much done. I blame too much turkey on Thursday.
The top of my B pillar wasn't right. There needed to be a rubber bumper there and wasn't enough room. So I cut and fixed what was wrong. Don't know how I was off when I did it but that is my way (a little off).
The door is really flexible with out the skin attached. I can twist it 1/2" with just my fingers. This also affects how the body lines match up. This is where I'm at with lining up.
I also started plug welding the rocker panel into place. Anyone else get nervous at this point. Did I forget anything? If I have to take it off now I could destroy it.
I'm a little worried about how the body gets wider on the suburban. Didn't notice it much at first. Now that I'm looking down the body to see if the lines are straight I can see it gets wider from the cowl to the back of the rear doors. Then it stays at that width to the tail lights. The passenger side seems to be like that too so it should be right. Is there anyone with a shiny suburban that can confirm it? Reflections will make it obvious if it's incorrect.
Travis
Old 11-25-2012, 09:28 PM   #170
jbclassix
Junk Yartist
jbclassix's Avatar
The roof line width gets wider on the burb body i am using. I am measuring from the pinch weld seams on the header panels. My pick up back half is 1 5/8" narrower.
-Jeremy
Rebuilding an NP205
Old 11-25-2012, 11:11 PM   #171
pickup67man
That makes sense. I knew they were different when I did floor repairs. It continues to get wider to the back door jambs. The back of the rear doors at weather stripping is 3/4" wider than the back of the front doors. And that is wider than the trucks? I need to measure a truck cab. I'm just trying to figure out how the side will look.
Travis
Old 12-09-2012, 07:51 PM   #172
pickup67man
Finally got tired of looking at the large gap at the front of the back door.
These little clamps are the best thing. Can't have too many.
Then lots of welding to get the addition on. I plug welded the skin to the door frame then added the extra 7/8".
After I got the edge fitted so the door gap was close I added another layer of sheet metal to the back. It sandwiches the lip from the door frame and I plug welded it to the door frame also. Then welded the two edges together to make it thicker.
If anyone ever says you have too many clamps show them these pics. I could use a few more.
After much grinding it looked like this. And with the two layers with staggered joints it is very rigid.
Here is the inside layer of metal after I plug welded it.
And after I finished grinding it. Looks clean. Will add seam sealer to edge before painting.
I started the back edge of the door also. It was also just one layer of sheet metal that is plug welded to the door frame. Added a layer inside like the front and got it ground down to set the door gap and ran out of steam for today.
Now I need to finish the back and then do the bottom to get the gap correct.
Travis
Old 12-09-2012, 09:00 PM   #173
Very nice. You have way more patience than I.
Old 12-10-2012, 12:33 AM   #174
jbclassix
Junk Yartist
jbclassix's Avatar
Ding!! You just gave me an idea for the front edge of my doors!!! Thanks man!
-Jeremy
Rebuilding an NP205
Old 12-10-2012, 12:41 AM   #175
pickup67man
If you have as many donor doors as I have you are in good shape. I cut just in front of the door handle and had to section almost 1/4" to get the body lines to match.
Travis
