lower standards
anyone have any good suggestions for a lowering kit?
Re: lower standards
Without knowing how low you want to go or what kind of lowering kit you are looking for it's hard to say...I don't have one yet but I have heard lot's of good stuff about ECE's lowering kits.
Jeramy CURRENTLY OWN, 72 c10 project/driver 2010 Kia Forte Koup SX daily driver 88 cherokee wheeler and dog hauler 2001 drz 400 Miss my 2004 firebolt (stock) and 2001 superhawk with a ton of modifications and many other previous vehicles. |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: lower standards
Re: lower standards
i was just thinking lowering springs.
i think my truck is already lowered the original owner told me. here the stance of my truck now |
Re: lower standards
Looks great how it is but another inch or two would look awesome.
1968 chevy lwb, getting ready to join forces with the 70 gmc 1970 gmc swb, getting ready to be a 68 chevy swb 1971 gmc lwb 2500 2wd Sierra Grande 1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins |
Re: lower standards
That looks to be a 3"front-5"rear. drop
Love That '69
Re: lower standards
I love the rims/tires on your truck!!
I AM CANADIAN!!!!! ![]() 1969 Chevy C/10 Truck - SBC V8, TH-350, 3.73 Posi, 1000W Rockford Fosgate Stereo System, B&M Megashifter, GT Grant Steering Wheel, Dual Magnaflow Exhaust System, Dynomax Headers, Lowered 1" Front & 3" Rear, Front/Rear Sway Bars, Racing Seats, 6000K HID Headlights 2008 Chevy Colorado LT - 3.7L I5, 4 Speed Automatic, Crew Cab, 4X4, Z71 Off-Road Package, "Ground Effects" Package, K&N Cold Air Intake, Supermod PTB, Magnaflow Exhaust w/ Resonator, 500W Kenwood / Rockford Fosgate Stereo System, Custom LED Lighting, 6000K HID Low's / High's, Blackcat Customs Gauges / Needles, Carbon Fiber Interior Accents, KrFabs 2" Lift Shackles / Torsion Bar Crank with Rancho RS5000 Shocks, Superskids Skid Plates |
Re: lower standards
Thanks i love the the ralleys with the white lettering. i was thinking another inch would look better. to help fill up that wheel gap
Re: lower standards
If I am correct on the drop Than you can still go lower in the rear 1-2 inches withouth notch if you do not plan on loading that much. For the front it looks like you will need drop spindals/drop coils which ever or both but will also need to put disc brake up front to work for the spindals. So you could go 5.5" front and 7" in rear. But to me for that drop i rather have airbags. So i could enjoy driving stock height and then slammin it when parked. I can not go with static drop anymore just no fun to drive. haha been there done that.
Re: lower standards
sounds like a bigger job than i expected...
Re: lower standards
Get the ECE 4/6 drop kit and you won't regret it. Has you truck been converted to discs already? Or is it still drum brakes?
![]() ![]() Join Date: Jan 2011
Re: lower standards
Naa, dropped spindles are not a big deal to install. It looks scary if you have never done it but as long as you have the right tools and you secure the springs you're good.
Do you know how the truck was lowered originally? Ex. It may already have dropped springs in it. If you go with an 'even shorter' spring you may have alignment issues start to creep in. I'd vote dropped spindles, all the way. Is it 5 lug or 6? Good lookin Stepper! Later.
Re: lower standards
unfortunately its still a 6 lug truck with drum brakes. the guy never told me how it was lowered, but im guessing he cut the springs.
Re: lower standards
To go with drop spindles, you will need to swap to disc brakes. That's not as bad as it sounds, though. It's actually a pretty simple swap. You can now buy 6-lug kits that even use the earlier ball joints and tie rods, so nothing else has to be changed.
Also, swapping to disc brakes is an invaluable upgrade.
#15 |
Re: lower standards
Ok a little lag on lowering my truck, I ran into other projects, but at the end of the month I will be purchasing a front disk brake conversion kit with 2.5 in drop spindles, in addition I will buy 2 inch lowering springs, so in total that should be 4.5 in drop in the front and for the back ill have 5 inch drop ( 3 inch drop springs and 2 inch lowering blocks). But I'm thinking that that won't be level and the back will be higher than the front, I have t bout the lowering blocks yet. So are they're any suggestions?
Posted via Mobile Device |
#16 |
Re: lower standards
Here is my 1969,Static 6/8 drop..... the rear is ECE with the panhardbar and 6'' coil and 2.5 blocks...the front is vintage "Dropshop" a-arms with a 6'' coil....when i had the 17'' on it it was super low ...with the 22'' it raised it up a lot
[IMG] ![]() |
#17 | |
Re: lower standards
Now I'm at 4.5" front a 5.75" rear(5" drop coil and .75" block), and it still sits a bit unlevel, but has a nice rake. If I ever change wheels/tires, I'll go ahead and get 6" rear springs. Here's how mine sits right now. ![]() ![]()
#18 |
Re: lower standards
Stepbed,,,, did my 68 stepper the same as you and love it.
I don't think we get smarter as we get older. We just run out of Stupid things to do. |
#19 | |
Re: lower standards
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
