![]() Join Date: Jun 2011
I picked up this 69 about 5 years ago, here it is as it was when I bought it... 4G on the tach at 60mph doesn't translate to very good fuel mileage but the 4:10's sure make the stock 350 spunky.
Plans & specs Returning to original Black on Black color and Custom 10 badging as noted on original SPID, ECE 4/6 Drop, Boyd welding rear tank, stock motor with Edelbrock carb and Performer RPM intake, Hushmat Sound Deadening in entire cab and doors, Painless Wiring, Toyo Proxes II tires, 17" Torque Thrust, All interior pieces from Truckseats (board vendor) Seat Foam, Seat Cover, Headliner, Door Panels, Kick Panels, going with Rams Head Manifolds with Flowmaster 40 Series, Hugger Green engine color and black engine compartment, 3:73 12 bolt truck posi, Disc brake and 5 lug conversion, and wood bed. Last edited by ~Whitey~; 03-02-2015 at 03:05 PM. Reason: updated plans |
67cheby
![]() Join Date: Sep 2008
Re: Project 69SWB
good looking truck!
Re: Project 69SWB
Re: Project 69SWB
Here the initial tear down of the body from the frame...
Re: Project 69SWB
Bed off and in great shape except the floor is a little dented here and there, but I have a plan to fix that.
Re: Project 69SWB
Body off; time to pull the motor.
Re: Project 69SWB
Just finished power washing the frame... Sandblasting and powder coating are not in the budget; so it's wire brush, gator wheel and De-greaser for me.
Re: Project 69SWB
I figured I'd break the frame down into 3 sections.. rear, middle and front. I did the rear first... I scored this 373 posi after I had already spend a day cleaning up and installing the open 5 lug rear from the 72 donor truck... but I didn't mind at all doing that part over again with this posi.
Will probably end up running those rear brake lines myself.. don't like the way these look at all.
![]() Join Date: Jan 2011
Re: Project 69SWB
Subscribed! Good looking truck. Welcome to the board from SE TN.
Re: Project 69SWB
once again a budget crunch... I wanted to tuck my exhaust up tight and couldn't afford the fancy cross member, So I cut my hole and reinforced with some 3/16 flat bar and welded it all up. Also installed new poly bushings and made sure I greased them up real good... pressed them in using one of many shade-tree methods. Also the trailing arms where in good shape just needed some serious cleaning.
Re: Project 69SWB
Re: Project 69SWB
Getting ready to start on the front end rebuild/disc/brake conversion. I find myself playing musical chevy parts quite often. I need a bigger garage.
Tot Roddin'
Re: Project 69SWB
Great looking build from another MO member.
Cheers! Nate
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
Re: Project 69SWB
Nice truck,looking forward to the build process.4000 rpm at 60 ? what size tires are on there? That seems about 1000 rpm too much for that speed.
#15 |
Re: Project 69SWB
on to the front end... lots of stripping and cleaning.. ugh!
#16 |
Re: Project 69SWB
Thank you!
275/60/15's is what I pulled off. I thought it seemed high, but the rear end did have 4:10's in it. Last edited by ~Whitey~; 12-10-2012 at 04:34 PM. Reason: spelling |
#17 |
Re: Project 69SWB
I think this front end took me twice as long to get cleaned up as the rear and middle section of the frame. Years of neglect can cake on hard. Got the front member all cleaned up and painted.. I let it bake in the sun all day and have some nice Grade 8 hardware waiting to put it back in with.
#18 |
67cheby
Re: Project 69SWB
nice work !
#19 |
Re: Project 69SWB
Here's the front member back in and all torqued to spec, gearbox installed, brake lines ran, motor mounts installed... I did have one cracked motor mount that I repaired.
#20 |
Re: Project 69SWB
#21 |
Re: Project 69SWB
72 spindles from the donor truck. I used my 69 upper and lower arms (they were in much better shape than the 72's) I got some new parts to finish up the front end.
#22 |
![]() Join Date: Mar 2010
Re: Project 69SWB
Nice start ... Keep up the good work.
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629 1969 custom/10 swb--SOLD 1968 swb 50th anniv.--SOLD 1967 camaro ss/rs..LS-6-speed, 16-year long project 1956 chevy nomad 1955 chevy 210 2-dr sedan 1978 el-camino ss 1-owner |
#23 |
Re: Project 69SWB
Looking good.
#24 |
Re: Project 69SWB
looking good, and nice starting point. did i see this truck on craigslist awhile back or am i imagining things.
77 CHEVY - SHORT BED STEP SIDE 2WD 02 CHEVY - EXT CAB SHORT BED Z71 7 INCHES OF LIFT |
#25 | ||
Re: Project 69SWB
Thank you. Quote:
Posted via Mobile Device |
| Bookmarks |
| Tags |
| 1969, black, custom 10, fleetside, shortbed |
