Old 12-09-2012, 09:13 PM   #1201
CC69Rat
CC69Rat's Avatar
Re: Project Grande Slam: Coley's Hot Rod Shop
Just doing research right now.. possibly next fall ( so I can keep it running this summer and finish up my stepside)
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 12-09-2012, 09:22 PM   #1202
Rusbuilt
Rusbuilt's Avatar
Cool man! I have a 5.3 and a lot of parts I won't be using if you're interested I will make you a deal! The engine needs to be rebuilt though.
Rusbuilt is offline   Reply With Quote
Old 12-09-2012, 09:24 PM   #1203
shawno72
C/10 junkie
shawno72's Avatar
Everthing is turning out real nice for ya Chad. I'm glad, it couldn't of happened to a nicer fella.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 12-09-2012, 09:48 PM   #1204
CC69Rat
CC69Rat's Avatar
Thanks guys- I have been really stressed about my job lately. This new job, man.. I really hope it works out.. Its more along the lines of what I know and like to do.
My trucks were on hold for a minute. Ill be back in the game soon.
Chad
Old 12-10-2012, 08:13 AM   #1205
bossmanivy
bossmanivy's Avatar
I hope things work in your favor with the job. I'm excited for you! Hurry up with that bathroom so you can get back on the trucks!
my build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=548037
bossmanivy is offline   Reply With Quote
Old 12-10-2012, 02:54 PM   #1206
superflysteiny
superflysteiny's Avatar
When I saw you had to repair the wheel I thought it was something I did and you did not see. My heart started to race. Then I looked back on the thread and saw what had happened. I am sorry that happened but at least you fixed it
superflysteiny is offline   Reply With Quote
Old 12-10-2012, 03:03 PM   #1207
CC69Rat
CC69Rat's Avatar
Nooo.. man it was a crazy kid with a four way lug wrench! I about passed out.
Chad
Old 12-11-2012, 08:33 AM   #1208
CC69Rat
CC69Rat's Avatar
I need some help fellas ..
I am in the market for my Master Cyl, and prop valve for the disc/disc setup. What are you guys running? I looked at CPP this morning and they have a Tandem Chambered type for $259
http://www.classicperform.com/Store/...260-8556-P.htm
This one looks really clean to me. they have one that's solid black eCoat too for the same price. This one is 1 1/8" bore too. I have a brand new OE booster I could run .. but my question is, .. does this MC even need the booster? I see some of the guys running Wilwood (Raull, N2Billet) that appear to have this same MC, but no booster? Is the Prop valve built in to this MC? Pretty cool ..
Help me choose please. What would you guys run? My truck was original power drum up front. Realizing I might need to change and / or run new lines for this one.. your thoughts?
Chad
Old 12-11-2012, 08:46 AM   #1209
lolife99
67-72 parts collector,…
lolife99's Avatar
I'm running this M/C on my stepside.
If you like the feel of brakes with a booster,... this will definitely be a different/harder pedal without the booster.
I have a manual set up on my red '69 with an aftermarket prop valve.
When I switch it to rear disc brakes,... I'm going to run a Wilwood M/C and just install an adjustable prop valve in the rear line.
(mounted under the cab on the frame)
This way I can clean up the brake lines under the hood.
Keith
Convert to disc brakes.
Old 12-11-2012, 08:57 AM   #1210
CC69Rat
CC69Rat's Avatar
I'm an ole Heel/Toe Boris Said type driver .. I like to drag the brake a little, so I guess a hard pedal would not be for me. So this MC would bolt up to the original booster ? I thought I might get the black one so it goesn't look so 'Aftermarket' compared to my other stuff under the hood now. Black booster, black MC?
Am I correct and the prop valve on this one is built in to the MC? I'm just not a big fan of the bracket hanging down beneath it for the prop valve. I'm open to put it on the frame rail too though. Would you have any reference material, pics of how it's done?
Chad
Old 12-11-2012, 09:07 AM   #1211
lolife99
lolife99's Avatar
The Wilwood M/C will bolt up to your booster.
There is no built in prop valve.
CPP sells a M/C of their own brand that has a built in prop valve,... but I've never used one.
I'll look for some pics.
And if you decide to get the Wilwood M/C,... try Summit Racing or Jegs.
They keep them in stock.
I think n2billet runs a 7/8" bore M/C on Hazel's manual brake set up.
I have a 1" bore on my '69's manual set up.
I think you would want a 1-1/8" bore for your disc/disc power set up.
Maybe someone else will chime in with their opinion.
Keith
Old 12-11-2012, 09:22 AM   #1212
lolife99
lolife99's Avatar
Wilwood sells just the adjustable "in-line" version for the rear brakeline.
Just make sure you order the correct version.
They have 3,... with different thread sizes attheports.
( I would use the inverted flare version)
They also have a new style adjustable prop valve that incorporates a brake light switch.
Keith
Old 12-11-2012, 09:27 AM   #1213
lolife99
lolife99's Avatar
I also have the black version of this M/C on my stepside project.
But I'm running a SSBC adjustable prop valve mounted on the frame.
Keith
Old 12-11-2012, 09:28 AM   #1214
CC69Rat
CC69Rat's Avatar
So the lines would run out of the MC, then into the Prop valve, and out to the wheels.. (?) I am pretty sure that's correct. Which side of the frame rail would be better, driver / pass ? Is it better to have the valve closer to the MC or further away .. Assuming all new lines and custom bent tubing ?
May be goofy questions, but that's how I learn. Thanks for your help.
Chad
Old 12-11-2012, 09:29 AM   #1215
CC69Rat
CC69Rat's Avatar
That's it right there man. WOW.
So I could do this same setup with a booster to make it less of a 'hard' pedal feel ?
Chad
Old 12-11-2012, 09:31 AM   #1216
lolife99
lolife99's Avatar
I mounted my prop valve on the drivers side.
I never understood GM's reasoning for running the REAR line across the back of the crossmember to the passenger side,... and then down the frame rail to the rearend.
I ran my new rear line down the driver's side frame rail.
Keith
Old 12-11-2012, 09:33 AM   #1217
lolife99
lolife99's Avatar
Sure.
I would contact Wilwood and ask them about the correct bore for a power brake set-up.
http://www.wilwood.com/MasterCylinde...ter%20Cylinder
http://www.wilwood.com/PDF/DataSheets/ds487.pdf
Keith
Old 12-11-2012, 09:44 AM   #1218
lolife99
lolife99's Avatar
This is CPP's M/C with built in prop valve,...
http://www.summitracing.com/parts/cl...501c/overview/
Keith
Old 12-11-2012, 09:52 AM   #1219
CC69Rat
CC69Rat's Avatar
That black Wilwood MC is killer though. I think that might be the ticket. I like the idea of adjustability for the rear 'kick' too. What do most people run 65/35 or so ? (35% rear?) I have never had a 4 wheel disc setup before. .. just not sure how it's setup. Just adjust it to my liking?
( I have on newer cars, .. just not something I installed I mean. I have had 1LE Z28, Corvette, Trans Am, BMW 335, etc.)
Chad
Old 12-11-2012, 09:54 AM   #1220
big_al_71
big_al_71's Avatar
I have the willwood manual master cylinder and proportioning valve have been driving it for a year now. the pedal is hard but it stops on a dime.. i wanted the clean look of not having a big booster in the way.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 12-11-2012, 09:59 AM   #1221
big_al_71
big_al_71's Avatar
here is another angle
Old 12-11-2012, 09:59 AM   #1222
CC69Rat
CC69Rat's Avatar
^^ Friggin sweet man .. That's the one I want. So, I just need that MC (figure out the bore size) and an adj prop valve? . . and of course my lines and stuff.
Running the big bore and this booster with adjustability do you think it would stop my mighty 350 and 3OTT ?
Chad
Old 12-11-2012, 10:11 AM   #1223
big_al_71
big_al_71's Avatar
Without a doubt!!!
It definetly stops my small block 406 with my heavy foot on both gas and brake pedal..
Old 12-11-2012, 10:17 AM   #1224
CC69Rat
CC69Rat's Avatar
I think you need a twin turbo LS in Sylvester Al.
(jus kididn man .. )
Chad
Old 12-11-2012, 10:49 AM   #1225
big_al_71
big_al_71's Avatar
Sylvester is done!!
Unless this motor gets hurt other than that it is "Finished"
