Old 12-08-2012, 11:19 AM   #1
54 jimmy
54 jimmy's Avatar
stock mirror holes
i bought new mirrors for my truck a while ago. i went to install them and the mirror brackes/arm holes don't line up. anyone using stock mirrors and can measure where the holes should be on the body it would be a great help.
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver) sold
1996 chevy k1500 reg cab 4x4(daily driver)totaled
2008jeep patriot (wife's daily driver
2008 chevy 1500 ext cab 4x4 sold
2011 chevy 1500 crew cab ltz (daily driver)
1996 chevy 1500 reg cab 4x4 project sold
2006 pontiac grand prix gxp (daily work commuter)
54 jimmy is offline   Reply With Quote
Old 12-09-2012, 04:36 PM   #2
Oklahoma_k5
Re: stock mirror holes
The vertical lines are measured as if the front of the cab were against a wall measuring back. Horizontal is up from the ground with the top of the frame being about 10. I've looked all through this factory assembly manual and this is the best I could come up with.
Oklahoma_k5 is offline   Reply With Quote
Old 12-09-2012, 07:27 PM   #3
54 jimmy
54 jimmy's Avatar
thanks for that i just got home from the garage. i installed the mirors using the measurements my friend got off one of the trucks sitting in his father in laws field. i only had to drill one hole and weld 3 up. gota love what past owners did.
Old 12-09-2012, 08:05 PM   #4
longbike
longbike's Avatar
If you look on the inside of the door you can see the three holes already cut into the bracing just drill to the center of all three.
longbike is offline   Reply With Quote
Old 12-10-2012, 07:03 AM   #5
54 jimmy
54 jimmy's Avatar
mine don't mount to the door they mount to the cowl area. i should have mentioned my truck is an ad model not a tf model.
Old 12-10-2012, 10:20 AM   #6
mknittle
mknittle's Avatar
Look under the dash there should be welded in braces with the holes punched in them.inside the cowel.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 12-10-2012, 10:20 PM   #7
54 jimmy
54 jimmy's Avatar
that would help if there wasn't holes already drilled and filled with crappy weld but the previous owner/owners. but i got them in the right spots i think. well close enough. thank everyone.
Old 12-11-2012, 11:16 AM   #8
mknittle
mknittle's Avatar
as long as they are pretty close and fit right it is alwase a compromise. just gotta pick the ome that works best
Mark
My GMC build.
