Old 12-05-2012, 10:04 PM   #1
Madfish
Aol ?
My truck has a mild notch in the rear. My ? is can i get the axle to air out close to bottoming out on the notch with an air over leaf setup?
Madfish is offline   Reply With Quote
Old 12-06-2012, 04:16 AM   #2
andrewmp6
Re: Aol ?
Don't use air over leaf it will crack and break the leafs over time over stressing them.What year truck is it ?
Old 12-06-2012, 06:41 AM   #3
bk2life
Re: Aol ?
does your truck coem close to bottoming out in the notch right now?
because if no, how are you going to put an air bag on the leaf and make it come down? the only way to do that is removing leaves to make the truck sag. that isnt the right way to do it.
your tryin to get your truck to lower itself more, how much lower do you need to get in the notch?
bk2life is offline   Reply With Quote
Old 12-06-2012, 12:33 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Aol ?
Seriously? Normally you give pretty good advice. You missed the target on this one all together.
Yes, if you run the two top leafs you will bottom on the notch just about the same time the pumpkin hits the bed floor. I suggest a small button style bumpstop inside the notch to keep the axle from bottoming out and save cutting your bed floor.
You might play with adding blocks as well. On my 77 we added blocks to allow me to run more bag pressure for a smoother ride.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-09-2012, 12:27 AM   #5
Madfish
Re: Aol ?
I knew i could count on you N2TRUX! It's an 83 by the way. So i need to keep the 2 longest leafs on each side, right?
Old 12-10-2012, 12:52 PM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Aol ?
Thats what we did Madfish. We ran the top two leafs and it worked just fine.
Articles-
"Refining Sierra"
Old 12-11-2012, 11:33 AM   #7
blazer2007
Re: Aol ?
I used a 1 inch block on mine and it helped with some extra room for bags and brackets
blazer2007 is offline   Reply With Quote
