damaged vin plate
Well while digging through my truck I noticed the vin plate is damaged severely. The upper part of it where the rivets are is broken what do I do?
Posted via Mobile Device |
Re: damaged vin plate
So, You have a damaged cab VIN plate.
Your cab VIN does not match the frame VIN. http://67-72chevytrucks.com/vboard/s...d.php?t=555876 Your frame is not the same series as the cab. http://67-72chevytrucks.com/vboard/s...d.php?t=555880 Sounds like you have an issue here. These questions are really all the same thread/issue. Has the truck been titled in your name? Has it had a VIN verification? Before you do anything with this truck get the paperwork and the truck correct to a point where it will pass a roadside traffic stop. Here in California the title is to frame VIN. If you go ahead with this remember it will not be a true C/20 truck with a C/10 frame and or suspension. The C/20 frame is heavier.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Interesting , I actually have lost the vin tag from my cab and can not locate anything on the frame . I went to our dmv and they told me when the truck is all done , they will come and inspect it, and retag it. They said as long as I have the original title they will do this with any issues.
