Old 12-12-2012, 12:08 PM   #11
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Originally Posted by RWB-713 View Post
Yeah, the cab floor & cab supports right there are notorious for always having cancer too, definately had to cut that out on mine as well. I didn't quit have to go as far up the cab as you did tho.
Supporting that corner definately is a good saftey measure considering how far up the cabside you had to go, i didn't support mine, but there's still alot of structural stability left in it.
Good work so far!
Thanks RWB-713. I'm gonna try to get all this metal work done as quick as I can so I can get some epoxy primer on it.
Question?: Should I epoxy prime after the metal work and before any body work? Or do my body work on the bare metal then epoxy prime afterwards?
Jimmy
.69SWB Build.
~Whitey~ is offline   Reply With Quote
1969, black, custom 10, fleetside, shortbed
