Old 12-14-2012, 01:58 AM   #1
lts70
1970 Daily Driver
lts70's Avatar
Need help to ID rearend
I tryed looking on the top of the passenger side axle tube for numbers stamped in like on my 70 but didn't find anything. What axle do you guys think this is?
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance.
lts70 is offline   Reply With Quote
Old 12-14-2012, 02:44 AM   #2
bk2life
Re: Need help to ID rearend
looks to me like a 1970 GM drum brake axle.
bk2life is offline   Reply With Quote
Old 12-14-2012, 08:59 AM   #3
69GWC
10 bolt.
69GWC is offline   Reply With Quote
Old 12-14-2012, 11:50 AM   #4
lts70
1970 Daily Driver
lts70's Avatar
Is there a way to identify what car it came off of to help with buying brake parts down the road?
Old 12-14-2012, 12:35 PM   #5
lts70
1970 Daily Driver
lts70's Avatar
I had a friend tell me the stamp is located on the passenger side axle tube 6" over from the pumpkin. I will try that.
Old 12-14-2012, 07:05 PM   #6
lts70
1970 Daily Driver
lts70's Avatar
I found the stamped number on the pasenger side tube.
It reads : 6GF P066D
Does anyone have a link that helps decode this number?
Old 12-14-2012, 10:29 PM   #7
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Originally Posted by 69GWC View Post
10 bolt.
No 10 bolt came original in these trucks. Eaton HO's have 10 bolt covers, as do Dana 60's.
GAry
'cuz chicks dig scars...
I would never rebuild a 305.
Old 12-14-2012, 11:02 PM   #8
lts70
1970 Daily Driver
lts70's Avatar
I should have put this in the 55-57 fourm. The axle is in a 1956 3100 SWB. I think it may have came out of a camaro.
