v8 and 6cyl driveshaft length
Is there any difference in length?
Posted via Mobile Device |
Fabricate till you "puke"
Re: v8 and 6cyl driveshaft length
Yes, the V8 smallblock vs the inline 6 (assuming same trans), will be 3 1/2" different in lenght. That is pluss or minus 1/8", & figured on original factory mounting points. It is best to do your own measure, do to the age of the truck.....you have to be sure that it has not been swapped before, with missmatched parts
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Does 79.5" sound right? For a v8 4spd
As said, you need to do the measure....check with your local driveline shop, so you get it right on
Got under and measured 79.5 so I was just wondering what a stock v8 manual trucks drive shaft was
