how does the ammeter work?
I have been wondering why mine doesnt work here lately. I everything works as far as the gauges but thats because the cluster harness is plugged in right? Does the ammeter work different because i noticed it has tw0 prongs on the back of it. HELP me out.
'84 swb chevy '69 swb chevy '68 swb chevy '95 Impala ss-sold '89 chevy crew cab dually 3+3 |
![]() Join Date: Dec 2012
Re: how does the ammeter work?
As I recall there is a little dinky P.I.T.A. fuse in a small rubber connector behind the battery. I want to say it is in a brown wire.
It has been a while since I replaced it though.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Here's a few threads to read. They will answer your questions.
...........http://www.google.com/custom?domains...D%3A1%3B&hl=en
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
Active Member
![]() Join Date: Jul 2007
Ammeter works in series to voltage. That's why you have two wires -incoming 12vdc and outgoing 12vdc.
Mine would not work on my 68. First I made sure this ground clip was installed. I also replaced the engine to cab ground strap behind the drivers side head, installed a ground strap from engine to frame, cab to frame, bed to frame and one on radiator support. Basically you want to create a good ground back to negative battery. I got rid of a lot of all my gremlins, head lights work better and ammeter works great now.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
