Old 12-02-2012, 09:52 AM   #1
BAT
Which Lugs?
I am getting ready to swap my axles from 6 lug to 5 lug and have a pair of Moser axles getting ready to go in. My question is which lugs do I want? These say "typically used with disc brakes (7/16" - 20 x 1 3/4"), is that the size I want? Wheel wise I will be going with Weld Star Pros.
BAT is offline   Reply With Quote
Old 12-15-2012, 01:19 PM   #2
HotRod C/10
HotRod C/10's Avatar
Re: Which Lugs?
you need .530 knurl
http://www.moserengineering.com/axle...spline-30.html
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 12-15-2012, 01:48 PM   #3
BAT
Re: Which Lugs?
Thanks!!
Old 12-15-2012, 02:20 PM   #4
luvbowties
luvbowties's Avatar
Thumbs up Re: Which Lugs?
You can buy the studs from generally-local stores like NAPA. Other locals should supply them as well, maybe cheaper. The stud size from '71-upwards is 1/2-inch, 20 threads/inch, and .535* knurlsize (shoulder-size that presses into axle-flange-holes). *.535 should work just fine in a .530 knurlsize-diam. hole* NAPA price is approx. $2.50 each. Be sure to get grade 8!
As far as what lugnuts to use, it is generally best to check with wheel-mfg., as tapers vary from wheel to wheel.
HTH,
sam
luvbowties is offline   Reply With Quote
