Clean Fire wall
I would like to clean up my fire wall but not really sure what is best way to go about this. For example, how to relocate the heating aparatus. So could someone explain the best way to clean up fire wall and maybe post some pics of their modified fire wall. Thanks. Any help will be appreciated.
Re: Clean Fire wall
I'm in the middle of it now / I'm going to get rid of the heat for the sake of cleaning it up
I also have pulled all the wiring from it's ends / just bought all new connectors rolling on grey metal primer all over firewall , wheel wells, front frame It's quite looking unreal under the hood these days , it's a stock 307 |
#3 | |
Re: Clean Fire wall
Re: Clean Fire wall
I know this is a different body style, but here are the steps:
1. Weld in filler plates, or one big piece as I did on the left side. 2. After all was fitted and checked with engine/exhaust/accessories, motor pulled 3. All wiring/hoses pulled off 4. Fully sandblasted (way easier then degreaser and power washer) best 150 bucks ever.. 5. Epoxy primer/body work 6. High build/body work 7. Paint. ![]() ![]() ![]() ![]() What would I have done different? Full piece of sheetmetal across the entire fire wall.. to which I most likely will still do before the motor goes back in, because I am a bit weird on details like that. ![]() |
#5 | |
Re: Clean Fire wall
Re: Clean Fire wall
The rivets and the copper look really cool. That is copper right?
#7 | |
Re: Clean Fire wall
Re: Clean Fire wall
Thanks to all of you for your replies. I hope to get my firewall looking as great as y'alls.
