#1 | |
Re: OOPS! HELP locked my drivers side door, now wont unlock
If you take the handle off, you can use ring nose pliers to take it apart. If you do so, there's a spring and several other pieces on the inside, so disassemble carefully and note the order in which they come out. I haven't taken the lock cylinder apart, but I'm sure finding out is easy.
My truck ain't dead, it just smells funny. |
thanks guys i got it, i took a set of needle nose pliers and grabbed that pin on the inside of the door that goes out the end of the lock cylinder and turned it counter-clockwise and it worked! the key turned with it!
