Old 02-08-2010, 12:30 AM   #1
John Fabris
TOTY 2006
John Fabris's Avatar
JF 68 Big Block Panel C20 to K20
Hi Gang,
Picked up a 1968 C20 Chevrolet Panel with 396.
It is a Custom trim level panel, no air and kinda runs.
My plans are to restore the body and interior, but then convert it from 2 wheel drive to 4 wheel drive. Already have a lowered 67 C10 truck, so this is heading up!
It appears that this panel has been repainted Silver poly, but the orginal Interior/Exterior Color is Fawn with chrome side trim, chrome window trim, chrome bumpers, also appears to have had the paint strip down the side, and the white nose.
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 02-08-2010, 12:32 AM   #2
John Fabris
TOTY 2006
Re: JF 68 Big Block Panel C20 to K20
More Pictures
John Fabris
67 C10 SWB
Old 02-08-2010, 12:38 AM   #3
John Fabris
TOTY 2006
So, I pulled the carb to check it out as currently it will only run as long as I keep tapping the gas (running on accelerator pump action, will not stay running on its own). So, While my boy (almost five years old) was sitting in the engine compartment and removing the four bolts I showed him, I started in on removing the carpet in the back.
So, carpet removed. ah, layer of grey foam.
Removed grey foam to find layer of green foam.
Removed green foam to find two layers of 1/4 inch plywood.
After that, ahh, a very nice shape wood floor, will clean that up and repaint
That is it for now. Will update as I get more time on this truck. Have a Olds 442 that I need to finish painting engine in reinstall. Once done with that, I will be back on the engine of the Panel to check it out and make a decision to run it or to pull to rebuild later and drop in my spare 402 engine.
Oh Yea, forgot, this 4x4 panel is the inspiration of what I wish mine to look like with the exception of mine will be factory style paint (fawn) with white nose and all trim including side trim that it once had.
John Fabris
67 C10 SWB
Old 02-08-2010, 08:52 AM   #4
70chevytruck
My hat's off to you. That thing is monster....love the wood floor though.
70chevytruck
70chevytruck is offline   Reply With Quote
Old 02-08-2010, 09:21 AM   #5
olblue60@aol.com
member
Nice find! Keep the pictures coming!
John
1967 C/K10 Chevy Panel
1968 C/K20 Chevy Pickup
1968 C/K10 Chevy Suburban
1941 Chevy Sedan Delivery
1960 Chevy Sedan Delivery
1972 Camaro SS 396 #s matching
1971 Harley FX Superglide
olblue60@aol.com is offline   Reply With Quote
Old 02-08-2010, 09:31 AM   #6
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Looks like a fun project, and look at that floor... my oh my...
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 02-08-2010, 10:14 AM   #7
hgs_notes
GEARHEAD
hgs_notes's Avatar
Anywhere/anyone else and they would have found a few rusted bits of supports and a couple slivers of wood under that foam and plywood. Congratulations. I know someone else that built the same thing from a long parked panel. Someone had been living in it out in the stix for awhile. It turned out very nice.
Good luck with yours.
hgs_notes is offline   Reply With Quote
Old 03-02-2010, 08:15 PM   #8
John Fabris
TOTY 2006
Got a chance to spend a little time on this last weekend. Timing is off, and appears that floats are too low. will not stay running. Checked oil before starting, looked brand new, after ten minutes of running it, water in oil. Yippee... drain radiator, drain yucky oil, new oil in, pulled spark plugs, all gapped wrong, range was 28 to 40, changed all to 35. Compression check, all cylinders between 158 and 165, except for #2 at 135. Also while draining oil, notice a buckle in the passenger frame rail. Another Yippee...
Alright, next chance I get on truck is to change the slot mag out for some stock 16.5 steelies (narrow ones) as I want to get rid of the slots. Then will pull intake manifold and pull both heads to see if I want to pull motor or just regasket for now.
John Fabris
67 C10 SWB
Old 12-29-2010, 08:41 PM   #9
John Fabris
TOTY 2006
Have it running enough to move around the yard. Been collecting the parts I need for this project.
Here is a shot of 6 of 9 wheels I have so far, still not a set of 4 with same offset.
These are 16.5"x9.75" wheels, (4.5", 5", 5.5" offsets)
John Fabris
67 C10 SWB
Old 12-29-2010, 08:42 PM   #10
John Fabris
TOTY 2006
4x4 hubcabs for the 16.5 wheels.
John Fabris
67 C10 SWB
Old 12-29-2010, 08:43 PM   #11
John Fabris
TOTY 2006
52 inch rear springs (rumered to be 6 inch lift) to use for the front end conversion.
John Fabris
67 C10 SWB
Old 12-29-2010, 08:44 PM   #12
John Fabris
TOTY 2006
used set of TSL SuperSwampers 35"X16.5" to use as rolling stock for use during conversion and fitment of new axles.
John Fabris
67 C10 SWB
Old 12-29-2010, 08:45 PM   #13
John Fabris
TOTY 2006
set of front and rear hooks to put onto the panel.
John Fabris
67 C10 SWB
Old 12-29-2010, 09:17 PM   #14
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice project, and very cool build!
Ryan
1969 Chevy milk truck
Old 12-30-2010, 12:52 AM   #15
67chevy1series
67chevy1series's Avatar
wow thanks diesel for bringin this up good builo
67chevy1series is offline   Reply With Quote
Old 12-30-2010, 10:37 PM   #16
John Fabris
TOTY 2006
YAA!!! Have a donor!!!!
1983 3/4 4x4 diesel suburban. This one is currently sporting a 396 big block, that is getting pulled and taken back to owner as part of the deal.
This appears to have a 10 bolt front axle, with a 14 bolt rear axle, NP208 transfer case, wih a 700r4 tranny. Now I need a flat cement pad to start working on all of this!!!
John Fabris
67 C10 SWB
Old 12-31-2010, 12:34 AM   #17
Dieselwrencher
Nice donor! 3/4 ton burbs are getting hard to find. Let alone a 4x4 one.
Ryan
Old 12-10-2012, 11:53 PM   #18
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Nice Panel! Did you ever get any further with this thing?
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 12-11-2012, 02:37 PM   #19
John Fabris
TOTY 2006
Project is still alive and kicking. I actually have a correct 1967-68 3/4 ton 4x4 frame from a Suburban now, and have just finished putting the front springs and axle (from the 85 4x4) onto the frame. Was able to resuse the 67-68 front leaf spring mounts as the 67 and the 85 have the same width springs, but did have to relocate the front spring rear hanger.
Have also been working on swaping the front crossmember (to use the later swaybar mounts) and will also swap in the engine crossemember and transmission crossmember.
As for the rear leaf springs from the 85, I have to trim some of the body mounts (on the 67 frame) for some clearance for the leaf spring hangers.
Already have the front tow hooks mounted. Will try to post pictures after I get home tonight.
I have to say that I hate frame rivets
John Fabris
67 C10 SWB
Old 12-11-2012, 02:55 PM   #20
Katrina/10
Katrina/10's Avatar
dig the custom interior door handles
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 12-11-2012, 07:06 PM   #21
thelonerife
thelonerife's Avatar
nice project. looking forward to some pics.
thelonerife is offline   Reply With Quote
Old 12-12-2012, 05:30 PM   #22
John Fabris
TOTY 2006
More stockpiling of parts, have lots of the 16.5x9.75 rims (but yet to have 4 of same style/offset), some extra doors, set of buddy buckets with passenger side folding. Other shots are of the new front axle bolted in, and front tow hooks on.
John Fabris
67 C10 SWB
Old 12-12-2012, 11:53 PM   #23
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Sweet!
I would offer to trade you two of my wheels for two of yours but shipping would suck and I think the different offsets will make the front and rear tires line up with the body better anyway so I'm not too worried about it.
Tony
Old 12-15-2012, 11:09 PM   #24
Beetle
Beetle's Avatar
Do you need some Ralleys? Also where is the LIKE button??? Big ole rat moving that panel, nice setup man!
Jason
TEAM C10 HOT ROD POWER TOUR
689 Short Step
68 Step
Trucks Sold: 70 GMC, 72 K5
Members met: Andy4639 GCncsuHD CSGAS zicc1835 hotrod farm truck Mingrao Bhelton brenthiggins
Beetle is offline   Reply With Quote
