#276 |
60-66 Nut
Re: D52 Caliper Rear Disc Brake Brackets
I received your payment today. I will get those shipped out on Monday.
You do realize that the D52's are the only caliper that will bolt up to these brackets, right?
#277 |
60-66 Nut
I have not had that issue with what I have mocked up here. One other customer has had that issue, but he has not gotten back to me with the measurement I need to determine what needs to be done to correct the situation. I don't want to just move the caliper out farther, and have the pads hanging past the outer edge of the rotor, if I don't have to. I just need someone to help me out with the measurement I need.
#278 |
A guy with a truck
Let me know what you need and I'll try to get it for you
Posted via Mobile Device |
#279 |
60-66 Nut
I don't have a pic of the dimension I need, on this computer. I will get it from my shop computer tomorrow and post it here.
#280 |
60-66 Nut
Here is a pic showing the dimension I need from those that have had a brake pad to rotor hat interference issue. Once I know what you have I can make the necessary change, and get you a set of brackets to correct the issue.
#281 |
A guy with a truck
You need the 3.5182 distance? I'll see what I can do this eve...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) Sporadically present, non-dues paying member of the world-famous Louisiana Classic Truck Club (LCTC). |
#282 |
60-66 Nut
Yes, that is the measurement I need. Yours may or may not measure 3.5182. Once I know what yours measures, I can have a set made that will solve the pad rubbing issue.
#283 |
60-66 Nut
Thanks for the purchase, and the compliment
#284 |
Building Dreams out of Dimes!
Will these parts work with the D52 brackets? Just checking before I order them.
ROTORS: http://www.summitracing.com/parts/eb...ro?prefilter=1 CALIPERS with ebrake: http://www.summitracing.com/parts/aa...model/eldorado I know i will have to get one for the passenger side and one for the driver side but I wanted to make sure I had the right ones. Thanks guys!
1981 Chevy short/wide. SB400 350th |
#285 |
60-66 Nut
Those look like the right parts......
#286 |
Cap'n,
Any news on the e-brake levers for the Eldo calipers? I'm waiting on the availability of those levers. As soon as they are, I'll be placing my order. We need an e-brake in TX to pass inspection. Thanks. |
#287 |
60-66 Nut
I don't have them done yet, but I'm trying to find the time to get them finished. I know there are a few of you guys needing them.
#288 |
60-66 Nut
I took some time today and made some progress on the Eldorado caliper levers and cable brackets.
I got 2 sets of levers formed up, but they ended up about 3/16" shorter than the originals. But I think they would still work. Regardless, I am going to order some longer ones laser cut next week. I also got the cable brackets drawn up on AutoCad, and will get some of those laser cut as well.
#289 |
#290 |
Got me some astro van rotors but they are way to thick for my Eldo calipers. Has anyone had this problem?
#291 |
60-66 Nut
Do you have the '76-'78 calipers? Which pads do you have?
#292 | |
#293 |
Yes I have the 76-78 calipers and I got Wearever silver brake pads. MFG NAD 122 Duralast Rotors Bolt Pattern Diameter (mm): 127 Rotor Bore Diameter (mm): 78.5 Rotor Initial Thickness (mm): 32.70 Rotor Outside Diameter (mm): 295 Rotor Overall Depth (mm): 83 Wearever Silver Brake Pads - Rear Friction Material Thickness, Inner Pad: 0.4 in Friction Material Thickness, Outer Pad: 0.43 in Front or Rear Brakes: Rear Fenco Disc Brake Caliper, Rear Right & Left I can not figure it out. I mean the rotors will NOT fit in the calipers with the brake pads installed....? The rotors are like .25 in too big..? Last edited by Hazieview; 01-30-2013 at 06:59 PM. |
#294 |
60-66 Nut
Did you check to see if the shaft is rotated as to engage the parking brake function of the caliper. If not you might try turning the shaft coming out of the back of the caliper. A box end wrench or a deep socket should work to grab it. I just don't remember what size off hand.
#295 | |
Posted via Mobile Device Last edited by Hazieview; 01-31-2013 at 07:21 PM. |
#296 | |
60-66 Nut
I have a pair of used calipers at the shop. I'll check out the fitment tomorrow and post my findings here. I have not heard of this issue from any of my other customers.
#297 |
Do you know of any customers that we can contact? Perhaps they can be of some assistance too. What size rotor, caliper inside width, and brake pad width and what brand they went with is all I need.
thanks!
#298 |
Would this work on a 69 Suburban C20 rear axle (8 bolt drum)
Thanks |
#299 |
60-66 Nut
Right now I can't think which of my custromers that have bought these brackets are using the Eldorado calipers.
I can not get a set of the D122 pads until tomorrow, but I did put a set of the D52 pads in a Eldorado caliper today. With the piston all the way retracted, there is 1.312" (1-5/16") between the pads. The pads I used were each about 9/16" thick. I'll check again tomorrow when I get the D122 pads.
#300 |
60-66 Nut
No, These only work with the '64-'82 GM truck 12 bolt and '80-'87 truck 8.5 10 bolts.
Does your Suburban have the Eaton HO52 or the Dana 60?
| Bookmarks |
