Old 12-14-2012, 08:04 PM   #1
ClassicNut
ClassicNut's Avatar
Hard Gas Pedal in 74
Changed from straight six and 3 speed on the column to 350 with 700R4 transmission. The gas pedal is very hard to push. We have used different springs on carb, new cables (both gas and transmission kick down). We thought it might be in the transmission as it had a full shift kit. We were going to check the springs in the transmission (found out the transmission was a mess). Ended up rebuilding the transmission. Still have the problem. Also had an angle on the cables going to the carb. Raised the mount so they are now straight. Does not feel hard at the carb. At a loss for ideas. Any help would be appreciated.
Kerry
1982 Chevy Corvette
1974 Chevy Stepside
1957 Chevy BelAir 2 Door Hardtop
1993 Cadillac Allante
1971 Dodge Charger R/T
ClassicNut is offline   Reply With Quote
Old 12-14-2012, 08:22 PM   #2
Low84
Low84's Avatar
Re: Hard Gas Pedal in 74
Maybe the cable itself is kinked or rusty
Never mind I read over the fact that you had already replaced them.
1978 stepside C10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=468265
Low84 is offline   Reply With Quote
Old 12-15-2012, 01:00 AM   #3
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
try making sure that the cable isn't kinked then shoot it through the end of the housing with WD40 or a lube
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 12-15-2012, 03:49 AM   #4
bk2life
new cables, but you might have kinked them with motor swaps?
bk2life is offline   Reply With Quote
Old 12-15-2012, 09:33 PM   #5
ClassicNut
ClassicNut's Avatar
Thanks for the responses. We have put a couple of new cables on it since all the changes. It did not help.
Kerry
1982 Chevy Corvette
1974 Chevy Stepside
Old 12-15-2012, 11:28 PM   #6
INSIDIOUS '86
INSIDIOUS '86's Avatar
What's the carb condition?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 12-16-2012, 02:56 AM   #7
Damien
Damien's Avatar
Can you post pictures, Something might jump out. I worked on a V8 to I6 swap a number of years ago and I don't remember having to change the cables.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 12-16-2012, 10:52 AM   #8
CobraJetKid
CobraJetKid's Avatar
I swapped out my Qjet for a 2bbl Holley and I'm having the same problem. Gas medal was nice and smooth before swap and now it's like stepping on a brick. Doesn't look kinked or anything but the bracket is mounted like 1/2" higher due to the adapter.
1977 K10 Silverado "The Heavy Chevy" - 350/350/203...Version 2.0 in progress: http://67-72chevytrucks.com/vboard/s...d.php?t=576865
1972 C10 Cheyenne "The Brown Bomber" - 307/SM465/12 bolt posi...Plans for 2.5/4" drop
1992 F-150 "The Dooley" - 351C/M715 axles/six 44" Swampers...BOSS 351 stroker pending
CobraJetKid is offline   Reply With Quote
