Old 12-13-2012, 11:11 PM   #1
brans72
^7 frame qustion on cleaning up
I am about to take the cab of our 67 C10 and tear down the frame completely! Anything you would do while apart if you could redo your frame or is just nice to do while apart? This is not a # matching truck. I will be cleaning up area where dimpled for power steering for sure be blasting frame but what else am I missing? Going to be going back with ECE 4/6 and might do c notch now just in case we tow and going to tear down front 83 crossmember and rebuild it. Any help guys?????? Brandon
brans72 is offline   Reply With Quote
Old 12-14-2012, 02:25 AM   #2
C0UCH
Re: ^7 frame qustion on cleaning up
Tagged for later. In the same boat with my 67. I'll be tearing it apart next week and looking for any tips/tricks/etc. Appreciate any input!
C0UCH is offline   Reply With Quote
Old 12-14-2012, 02:32 AM   #3
bk2life
pull everything off your frame. even your front suspension. take all the parts and get them sandblasted. then either powder coat or paint every thing.
then reassmble with all new front end suspension bushings/rebuild kit.
new bushings everywhere/leaf spring/cab/front end, everything.
that is what i would suggest. if you are guna do it, do it right.
bk2life is offline   Reply With Quote
Old 12-14-2012, 02:49 AM   #4
Sidewinder4.9l
Sidewinder4.9l's Avatar
I'll second this....Do it once; Do it right...
Wesley
1992 F-150 Michelle-300I6 w/ 5 Speed
Hurst Short Throw Shifter/ Cold Air Intake
1969 K/10 307ci-4spd
Sidewinder4.9l is offline   Reply With Quote
Old 12-14-2012, 03:30 AM   #5
ZenC10
ZenC10's Avatar
not that they needed it but i boxed my trailing arms. these frames are pretty strong, so its not necessary. i did it for a cleaner look and maybe a little strength. im in the middle of a complete frame off resto. let me know if ya have any questions. biggest thing is, plan ahead and take your time. you'll get out of it what you put in it. as far as satisfaction goes anyway! $ might be a different story... lol!
ZenC10 is offline   Reply With Quote
Old 12-14-2012, 08:10 AM   #6
CC69Rat
CC69Rat's Avatar
Cleaned, blasted and painted 69 SWB frame with 83 front suspension .. this is what it would look like!
Just trying to keep you motivated .. let me know if I can help you.
http://67-72chevytrucks.com/vboard/s...d.php?t=444414
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 12-14-2012, 11:47 AM   #7
longbed67
longbed67's Avatar
x3 Do it once, do it right.
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline   Reply With Quote
Old 12-14-2012, 10:41 PM   #8
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Decide if you're going to move the tank to the rear.If so,you probably want to mod the crossmember for that before doing the paint/powdercoat.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 12-15-2012, 07:30 PM   #9
67ctener
67ctener's Avatar
Just finished my frame on my 67... Things to do prior to paint/powdercoat. Indent frame if you wanna run a ps box, drill rear rivets for shock mount relocator kit, pretty much look ahead so you not cutting/drilling on a finished product
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
67ctener is offline   Reply With Quote
Old 12-15-2012, 07:50 PM   #10
nds1968
nds1968's Avatar
I drilled the rivets on my manual trans crossmember. I used bolts to reattached it after powder coating. I did this just in case I decide to go with a different transmission in the future.
If your not going with an aftermarket trailing arm crossmember I would modify it for the exhaust to run through.
I would cut the frame for a C-notch.
Nate
1967 short fleet Project Blue Goose
'If it don't bounce back... heeheehee you go hungry!" Blues Brothers
nds1968 is offline   Reply With Quote
Old 12-16-2012, 04:36 AM   #11
WIDESIDE72
WIDESIDE72's Avatar
I was going to mention these if no one else did. Also, if you don't currently have a front sway bar, you will need to drill out the two lower rivets on the front crossmember as the sway bar brackets use these same holes.
WIDESIDE72 is offline   Reply With Quote
Old 12-16-2012, 11:14 AM   #12
brans72
Great ideas guys and keep them coming! So far frame as be modded for power steering but will clean it up better before sending out, started the rear tank conversion but not sure about this crossmember mod that panel is talking about. Also can you post up on lower rivets for the sway bar? Might not work on mind since using 83 front crossmember. Also plan on doing the exhaust in crossmember but not sure what thickness to go with on metal.Can anyone post picture just to be sure for shock mounts I need to remove to install shock relocators please. Thanks for info guys!!!!!
Old 12-16-2012, 12:17 PM   #13
brans72
What does flipping the front bracket on the trailing arm do for or trucks? I also plan on welding up trailing arms and wondering if replacing the original bushings in the trailing arm are going to be a pain to remove and replace? Anyone rebuilt upper and lower control arms on 83 C10? Might as well do it once and do it right!
Old 12-16-2012, 01:03 PM   #14
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Check any brake lines that attach to the frame, clean & chase any fastener
holes, especially where ground straps go. Check the integrity of wiring & fuel
lines and replace if need be.
Forum Guidelines and Rules
Buying and Selling Code of Conduct
Become a Board Supporter!
Truck FAQ
Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member...
ETsC10 is offline   Reply With Quote
Old 12-16-2012, 03:06 PM   #15
WIDESIDE72
WIDESIDE72's Avatar
There is a rear crossmember that is in the way of mounting a rear tank. Simple physics, two things cannot occupy the same space. As for the sway bar mount, I don't have a photo, but if you had a sway bar and mounts you would see that from the factory sway bar equipped trucks had the frame bracket and the front crossmember attached to the frame with the same rivet. (truck sway bars dont bolt directly to the frame like a car, but use a bracket that is originally riceted to the frame that the sway bar then bolts to. Non sway bar trucks had only the crossmember, so in order to mount the sway bar bracket, you have to remove the river and replace it witha a good grade 8 bolt and lock washer.
Old 12-16-2012, 08:07 PM   #16
WIDESIDE72
WIDESIDE72's Avatar
Originally Posted by WIDESIDE72 View Post
There is a rear crossmember that is in the way of mounting a rear tank. Simple physics, two things cannot occupy the same space. As for the sway bar mount, I don't have a photo, but if you had a sway bar and mounts you would see that from the factory sway bar equipped trucks had the frame bracket and the front crossmember attached to the frame with the same rivet. (truck sway bars dont bolt directly to the frame like a car, but use a bracket that is originally riveted to the frame that the sway bar then bolts to. Non sway bar trucks had only the crossmember, so in order to mount the sway bar bracket, you have to remove the river and replace it witha a good grade 8 bolt nut and lock washer.
Old 12-16-2012, 09:05 PM   #17
CC69Rat
CC69Rat's Avatar
On the front trailing arm bracket flip, it basically takes away about 3" of drop that the rear axle housing and pinion angle would 'see', .. the pinion angle is more at an acceptable angle in relation to the drive shaft. It also helps with lateral regidity and the geometry of the trailing arm suspension a bit closer to stock but at a lowered ride height. The only down side is it takes away (raises) about .75" of your rear drop.
Yes, absolutely. While you have your trailing arms out, replace the bushings.
On the front upper / lower arms .. mine were already done when I got the truck.
Chad
