identifying the engine in my truck.
Alright I was told that the engine in my '66 is the original factory 327.
now the engine has power pack heads on it so it would be a 250HP 327 i read the suffix code on the front of the engine and came back with a 060IWA from what i can tell. what does this mean? here's what my engine looks like. ![]() |
Re: identifying the engine in my truck.
As far as I know, the best way to be sure is to get the engine number off the block behind the driver's side head, near the bellhousing...
DON Proverbs 27:17 ![]() US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
According to the small block suffix codes listed at: http://www.nastyz28.com/gm-chevy-cod...-suffix-10.php the "WA" is one of the following:
1965-up 283, 2bbl, 175HP, from a C10-35 truck 1968-up 307, 2bbl, 200HP, from a C10-25 truck 1969-up 350, 4bbl, 255HP, from a C20-35 truck So like Ta2Don said, it's best to get the casting number off the back of the block near the bellhousing. It can be hard to read with the engine in place so you might have to use an inspection mirror to see down in there. As for the rest of that "0601WA" code you found, the 06 = June (month the engine was originally assembled), and the 01 = 1st day of the month. There's usually a single letter prefix at the beginning of that code that indicates the engine assembly plant. |
![]() looks like the last 3 numbers are 852. 283 2 BBL 195 Horsepower |
"Where were you in '62?"
![]() Join Date: Jul 2004
Small Block Chevy Engine Block Identification
http://67-72chevytrucks.com/vboard/s...d.php?t=353538 Casting CID Year Model Aplication Comments 330817 400 73-76 Passenger 2 bolt main,3 freeze plugs/side 330817 400 75-80 Truck 2 bolt main,3 freeze plugs/side 355909 305 76-79 Truck 355909 305 78-79 Pass,Camaro,Malibu,Monte Carlo,Nova 360851 262 75-76 Monza 361979 305 76-79 Truck 361979 305 76-79 Pass,Camaro,Malibu,Monte Carlo,Nova,Chevelle 366245 350 78-79 Pass,Malibu,Camaro,Nova Dipstick in oil pan 460776 305 76-79 Truck 460776 305 78-79 Pass,Malibu,Camaro,Nova,Monte Carlo 460777 305 78-79 Pass,Malibu,Camaro,Nova,Monte Carlo 460778 305 78-79 Pass,Malibu,Camaro,Nova,Monte Carlo 471511 267 79-82 Malibu,Monte Carlo 3703524 265 55 Corvette 195 HP,no oil filter 3703524 265 55 Passenger No oil Filter provision 3720991 265 56 Corvette with no oil filter 3720991 265 56-57 Truck,Pass with no oil filter 3731548 283 57 Corvette,pass,truck no side motor mounts 3737739 283 58-59 Corvette Early 1959 3737739 283 58-61 Passenger 3756519 283 58-61 Corvette 3756519 283 58-62 Passenger,Truck 3782870 327 62-65 Corvette Sm journal 3782870 327 62-65 Passenger,Chevelle,Truck Sm journal 3789817 327 62-65 Passenger,Chevelle,Truck Sm journal 3789935 283 61 Corvette Late 1961 3789935 283 62-64 Truck 3789935 283 63-64 Passenger,Chevelle 3790721 283 64-65 Chevy II Recessed oil filter boss 3791362 327 65-67 Chevy II/Nova Recessed oil filter boss sm journal 3794226 283 58-62 Truck 3794460 327 68-69 Pass,Chevelle,Camaro,Nova Large journal 3837739 283 58-62 Truck 3849852 283 58-63 Passenger 3849852 283 58-67 Truck 3849852 283 64-67 Passenger,Chevelle 3849935 283 62-67 Passenger,Chevelle 3858174 327 64-67 Passenger,Chevelle,Camaro Sm journal 3858174 327 64-67 Truck Sm journal 3858174 327 66 Corvette 300,350 HP Sm journal 3858174 350 67 Camaro 3858180 327 64-67 Pass,Chevelle,Camaro Sm journal 3858180 327 64-67 Truck Sm journal 3858180 327 65 Corvette 3862194 283 66-67 Chevy II Recessed oil filter boss 3864812 283 63-64 Pass,Chevelle,Truck 3889935 283 63 Truck 3892657 327 64-67 Pass,Chevelle Std & Hi Perf sm journal 3892657 327 64-67 Truck sm journal 3892657 327 66-67 Corvette 300,350 HP sm journal 2 bolt main 3892657 302,327 67 Camaro & z28 sm journal 2 bolt main 3896948 283 65-67 Pass,Chevelle,Truck 3903352 327 64-67 Pass,Chevelle,Camaro sm journal 3914635 307 68-73 Pass,Chevelle,Camro, Nova,Truck 3914636 307 68-73 Pass,Chevelle,Camro, Nova,Truck 3914660 327 68-69 Pass,Chevelle,Camro, Nova,Truck 3914678 302,327,350 68 Camaro,Z28 large journal,2 bolt main 3914678 327 68 Corvette 300,350 HP lrg journal 2 bolt main 3914678 327 68-69 Pass,Chevelle,Camaro, Nova,Truck 3914678 350 68-74 Pass,Chevelle,Camaro, Nova,Monte Carlo 3914678 350 69-76 Truck 3914678 350 78-79 Pass,Malibu,Camaro ,Nova 3932371 307 68-73 Pass,Chjevelle,Camaro, Nova 3932371 307 69-73 Truck 3932373 307 69-73 Pass,Chevelle,Camaro, Nova,Truck 3932386 327 68-69 Pass,Chevelle,Camro, Nova Large Journal 3932386 350 69 Corvette 300,350 HP 3932386 350 69-74 Pass,Chevelle, Camaro,Nova,Monte HI perf,4 bolt main 3932388 350 68-74 Pass,Chevelle, Camaro,Nova,Monte 2 bolt main 3932388 350 69-76 Truck 2 bolt main 3932442 350 67 Camaro 3933180 327 68-69 Pass,Chevelle,Camaro, Nova,Truck Large Jounal 3941174 307 68 Truck 3951509 400 73-76 Passenger 2 bolt main, 2 freeze plugs/side 3951509 400 75-80 Truck 2 bolt main, 2 freeze plugs/side Casting # CID Year Model Application Comments 3951511 400 70-73 Pass,Chevelle,Monte 4 bolt main, 3 freeze plugs/side 3951511 400 75-80 Truck 4 bolt main, 3 freeze plugs/side 3955618 327 68-69 Pass,Chevelle, Camaro,Nova Large Journal 3955618 302 69 Camaro,Z28 early 69,4 bolt main 3955618 350 69 Corvette 300,350 HP,4 bolt main 3955618 350 69-74 Pass,Chevelle,Camaro,Nova,Monte Carlo 3955618 350 69-76 Truck 3956632 307 69-73 Pass,Chevelle,Camaro,Nova,Truck 3970010 350 69 Corvette late 69,4 bolt main 3970010 302 69 Camaro Z/28,Late 69, 4 bolt main 3970010 350 69-79 Truck 2&4 bolt main 3970010 350 69-79 Pass,Chevelle,Camaro,Nova,Monte Carlo 2&4 bolt main 3970010 350 70 Corvette 300,350,370 HP 4 bolt main 3970010 350 71 Corvette 270,330 HP 4 bolt main 3970010 350 72 Corvette 200,255 HP 4 bolt main 3970014 350 69-77 Pass,Chevelle,Camaro, Nova,Monte Carlo 2 or 4 bolt main 3970014 350 69-79 Truck 2 or 4 bolt main 3970014 350 72 Corvette late '72,200 HP,255 HP 4 bolt main 3970020 307 68-73 Pass,Chevelle,Camro, Nova 3970020 307 69-73 Truck 3970024 307 69-73 Pass,Chevelle,Camro, Nova,Truck 3992386 327 68-69 Pass,Chevelle,Camro, Nova,Truck Large Jounal 14010201 305 80-85 Pass,Malibu,Monte, Camaro,Nova,Truck 14010202 305 80-85 Pass,Malibu,Monte, Camaro,Nova,Truck 14010203 305 80-85 Pass,Malibu,Monte, Camaro,Nova,Truck 14010205 267 80-82 Malibu,Monte Carlo 14010207 350 80-85 Pass,Malibu,Camaro 14010207 350 80-81 Truck Light Duty 14010209 350 80-81 Pass,Malibu,Camaro 14010209 350 80-85 Truck Heavy Duty 14010280 267 80-82 Malibu,Monte Carlo 14016376 267 80-82 Malibu,Monte Carlo 14016379 350 77-79 Pass,Chevelle,Camaro, Nova,Monte 14016381 305 76-85 Truck 14016381 305 78-85 Pass,Malibu, Camaro,Nova 14016383 305 80-85 Truck 14088526 350 87 Camaro 14088548 350 86-88 Truck One Piece rear main seal 14088551 305 86-88 Truck One Piece rear main seal 14088551 305 86-88 Pass,Malibu One Piece rear main seal 14093627 305 87 Pass,Malibu One Piece rear main seal 14093638 350 86-87 Truck One Piece rear main seal 14093638 350 87 Camaro One Piece rear main seal 14101148 350 87 Camaro One Piece rear main seal 14102058 305 87 Truck One Piece rear main seal 14102058 305 87 Pass,Malibu,Monte Carlo, Camaro One Piece rear main seal 14316379 350 69-85 Truck Two Piece Rear Main Seal 14316379 350 78-81 Pass,Malibu, Camaro,Nova One Piece Rear Main Seal Online engine resources (casting numbers, calculators, etc.) http://67-72chevytrucks.com/vboard/s...d.php?t=382583 ![]()
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
