Old 11-02-2012, 09:54 AM   #1
71stub
71stub's Avatar
Who's done a 5.3L camshaft swap?
I've got a relatively stock 2004 4WD 1500 crew cab with the 5.3 in it and was pondering doing a cam swap. I had the computer tuned which seems to have helped but I pull a 20' car trailer a lot and have heard that a simple camshaft swap can gain me up to 70 rear wheel horsepower and a couple MPG's. Is there any truth to this? I've also been told by my local LS guru who also has his own dyno that removing the stock muffler and swapping in a Magnaflow or other muffler. He said to stay away from the chambered mufflers as they don't agree well with the LS series engines. So can anybody give me their feedback from a cam swap in a relatively stock application?
1971 Cheyenne Short Fleet - 468BB/TH400, Tilt, Tach, PS, PB
1967 Custom Short Fleet - 327/4spd
71stub is offline   Reply With Quote
Old 11-02-2012, 04:55 PM   #2
Sooner84
Sooner84's Avatar
Re: Who's done a 5.3L camshaft swap?
I would say do longtubes and exhaust first, thats what i did and it woke my 5.3 up quite a bit. I went with a hooker aerochamber muffler, its straight through and sounds great but not too loud until you get on it. I just put in a 212/218 low lift comp cam in it and love it and it works great with the stock torque converter. If youre going to do a cam, valve springs are a must, and i also went ahead and bought hardened pushrods. To gain 70 rwhp would take a little more but not much, also my MPG has stayed exactly the same if not better.
1984 chevy swb(1st truck, sold..)
2001 RCSB silverado, 5.3 with a little extra
2004 ECSB Silverado LT, 5.3 cam & bolt ons, 4l60e shift kit/stall, g80 & 3.73s
My first (1984 c10) Build
Sooner84 is offline   Reply With Quote
Old 11-02-2012, 05:40 PM   #3
71stub
71stub's Avatar
After having headers on my 98 I despise them on a daily driver. I plan on installing new valve springs with the swap also.
Old 11-02-2012, 07:05 PM   #4
Sooner84
Sooner84's Avatar
What didn't you like about the headers? I had headers on my 84's 350 and daily drove it. But These new motors benefit quite a bit from them.
Old 11-02-2012, 07:49 PM   #5
71stub
71stub's Avatar
I have Hedmans on my 98. Always leaking!! Gaskets, loose bolts, even cracked by the welds a couple times now. Not impressed...
Old 11-02-2012, 08:18 PM   #6
Sooner84
Sooner84's Avatar
Well you can still keep the stock manifolds, you just won't feel quite as much gains. I would run a an offload y pipe and a straight through muffler.
Old 11-03-2012, 12:24 AM   #7
Richardman1992
Richardman1992's Avatar
Go to the forum Performancetrucks.net there's where I learned a lot from. I just put in a comp 212/218 low lift still need to tune it. I would advise against a stall converter especially with towing. If I did it again insolent have bought a higher stall converter, but being that my truck is 4x4 it's not coming out. Get some eBay stainless longtubes lots of guys run those with no problem. No need for shorties as the stock manifolds flow pretty good. Avoid flowmaster like the plague. I have a spin tech muffler and I love it. Doesn't sound like your average flowmaster and dual tip equipped ls everyone and their mother drives...
2001 Silverado z71 ECSS Cammed, Stalled, headers, BB tuned
1988 Scottsdale 2500 ECLB 4x4- the never starting project
2021 Camaro LT1 LT1/M6/NPP fun car for the weekends
2008 Grand Prix GXP daily
Richardman1992 is offline   Reply With Quote
Old 11-03-2012, 12:26 AM   #8
Richardman1992
By the way, don't waste your money on a cold air intake with an open element filter. Replace the tube with something that flows better but leave the stock airbox. Blackbear performance did testing that proves the stock airbox works just fine
Old 11-03-2012, 11:06 AM   #9
71stub
71stub's Avatar
Anybody got a PN for a direct replacement straight thru muffler? I can't find a Magnaflow PN online.
Old 11-10-2012, 06:28 PM   #10
crazy longhorn
Fabricate till you "puke"
You might check with magnaflow, but I dont think you will find a direct replacement for the stock muffler. The stock tubing on my 02 ,was 2 3/4"....choices were 2 1/2, or 3" on the muffler. Running a 4.8, I choked the muffler down to 2 1/2, & Had a couple reducers made to fit. I used an offset/offset muffler (14" body), for a nice rumble. I canted the muff , till all the pipes lined up, & cranked up the old 200 amp Mig I love it, but if you like a tick more mellow, you might go 18" on the muff body? My old truck has a nice rumble around town.....easy on the hyway(to about 70 mph). If you drive faster than that on cruise, or OPEN the throttle , you WILL hear it The cat back duals are nice, but very pricey! They will run you 3" into the muff, & 2- 2 1/2" pipes out. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 11-25-2012, 04:29 AM   #11
Frostflowz
A cammed 5.3 is a wonderful thing. The hardest part was installing the valvesprings for me, everything is straight forward.
I am running a Comp cams 54-457-11, here a vid of idle.
http://youtu.be/qaYdCU8rNGc
Frostflowz is offline   Reply With Quote
Old 11-25-2012, 05:42 AM   #12
bk2life
I have Hedmans
did you tell them about the problems you are having?
hedman is a pretty big company and i have a friend who had problems with the fit of his old pair, he called them and they sent him a new pair of headers that were twice as much as he orignialy paid, better product all around.
you might try it..
bk2life is offline   Reply With Quote
Old 11-25-2012, 04:55 PM   #13
71stub
71stub's Avatar
I've never contacted them. These cracked out really bad at the collector. By the time I chased the crack around I used up a half roll of wire! When I pull them off I might contact them with pics to see what they say. Thanks for the input.
Old 12-17-2012, 07:00 PM   #14
BossHogg69
motor exploder
BossHogg69's Avatar
I installed a Comp LSr 265 w/Lunati springs (215*/233* & .604"/.610" - the smallest cathedral port LSr cam) along with a Yank TT2600 converter in my '05 GMC ccsb with a 5.3. The cam was fine with the stock converter, but with the Yank, the whole thing really came alive. I also have some stainless longtubes and 2.5" true duals with an 'X' placed 18" after the headers and Blackbear tune. Before the converter, the gas mileage was the same as stock. After the converter, it went down a bit, but some of that is because I now have a crew cab burnout machine
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
