Old 12-14-2012, 04:57 PM   #1
sumtercleaner
sumtercleaner's Avatar
lowering/ u-joint ?
Do the lowering via drop springs put any extra stress on u joints or any other parts?
sumtercleaner is offline   Reply With Quote
Old 12-17-2012, 09:29 AM   #2
sumtercleaner
Re: lowering/ u-joint ?
Reason im asking is after lowering the rear, i started getting a clicking when i first take off.
Old 12-17-2012, 09:50 AM   #3
CC69Rat
CC69Rat's Avatar
How big was the drop? 2" .. 6" ? It sounds like a pinion angle issue to me.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 12-17-2012, 11:31 AM   #4
Clyde65
Clyde65's Avatar
if your getting a ticking from the ujoint, it is already bad.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 12-18-2012, 08:22 AM   #5
sumtercleaner
The PO heated front springs down to the bump stops and only heated the rears and inch or so.... stupid look. So i heated the rears to bring it down some til. After christmas when the budget is a little better. Its by no means as low as it could go. Ill prob replace u joints but how can i change pinion angle? If it were leafs im familiar with those from my dirt track days.
Old 12-18-2012, 09:24 AM   #6
bk2life
pinion shims -same as your dirt track days.
bk2life is offline   Reply With Quote
Old 12-18-2012, 10:25 AM   #7
cdowns
cdowns's Avatar
with heated lowered springs that clicking can turn to a very loud crashing noises in less than a heartbeat// thats why they call cheapo heated drop jobs deathtraps
Old 12-18-2012, 02:12 PM   #8
sumtercleaner
Can some one post a link or part number so i can adjust the pinion? Again i am not familiar with adjusting pinion angle with coils. On coil race cars we never had a problems but on leaf cars we added 4° shims. My truck is coil
Old 12-18-2012, 02:46 PM   #9
CC69Rat
CC69Rat's Avatar
Sumter - Realizing you're trying to make a bad (Previous Owner) situation better, we're here to help you man.
Two ways on the coil / Traling Arm / Truck arm suspension. It sounds like you know this, but when the truck is lowered, the pinion where it meets the drive shaft yolk that angle doesn't change much at all. So essentially what you'll run into is the pinion angle will point UP too far toward the bottom of the bed floor. We need t ofigure out a way to 'Roll" that pinion angle back down. you can accomplish this by:
Flip the front trailing arm brackets upside down. This will take away about 3-4" of drop that the truck sees. So, what I mean is by moving that hinge point UP - ( where the trailing arms meet the cross member) then you can lower the truck without changing that pinion angle. This will also help you with overall handling because the truck arms will be at (close to) stock angle. The front mounting point higher than the back. The only downside to this is it will cancel out about .75" of your drop. If you raise the front mounting points, then you also raise the angle where it meets the spring perch and it will raise the truck.
Otherwise when you lower it, the trailing arms will essentially be laying purpendicular to the ground. .. and the truck will be bad to squat in corners and hard acceleration. This is even more important with a LWB .. just my opinion.
The next option as you mentioned would be shims. you can buy pinion shims for the truck trailing arm suspension. 4 deg sounds about right. I usually do 1 deg per 1" drop. .. on a SWB, but on a LWB it might be slightly different. You want a little bit of nose up on the pinion so when you take off the pinion will roll DOWN. .. and the drive shaft and pinion angles will 'zero out' I usually do 1-2 deg UP at ride height.
On the drop springs, yes .. absolutely. Heated springs are dangerous brother. Not trying to make a situation worse for you but what I'd do would be maybe a 4-5" drop spring .. and a 1" block ? then maybe 3 or 4 deg shims. If you're around 6" drop or more, I'd consider flipping the front brackets AND shims. I happen to have some extra front brackets if you need them. They are ROUGH to get out of there but it definitely helps wit hsituations like yours. while you have the drive shaft out it would be a great time to throw a new Ujoint in there .. Hint.
Later. Let me know if I can help you.
Welcome to the Board!
Chad
Chad
Old 12-19-2012, 08:57 AM   #10
sumtercleaner
Ok i found some shims at a reasonable price. (Stockcarproducts) going with 4° . The center support bearing that the PO installed is in half now. So that will be replaced as well. Thanks for the help, tips and concern.
