12-18-2012, 01:36 PM | #1 | |
I'm just glad to be here!
Re: Project Goldilocks, '66 C10 SWB BBW Build
Check out our thread for pictures, we do not have the LSA pan on yet, but the measurements say it will fit without issues. We are redoing the frame mounts for the engine now, so hopefully over the Christmas holidays we can get this put back together with the new pan.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
12-18-2012, 04:43 PM | #2 | |
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
12-20-2012, 01:02 PM | #3 |
Picked up my trans mount last night and the motor mount kit is on its way. I'm going to make the motor mounts tie the upper frame rail and to the crossmember like the stock mounts. I may chop up the original mounts and use the top half to hide the new mounts so it looks like a factory part.
12-20-2012, 01:43 PM | #4 |
Here is a link to where I got my LSA pan kit....it is a current auction and shows he has 3 left...
http://www.ebay.com/itm/261097128044...84.m1423.l2649
12-20-2012, 05:22 PM | #5 |
Those motor mount pieces look nice. I haven't seen a kit like that where you can locate your own mounting tabs. I went with the Dirty Dingo mounts which are basically the same idea, only the tabs are already welded and the holes are slots for motor location adaptability.
12-20-2012, 05:55 PM | #6 | ||
Looks like clearance would be good with the LSA pan, but I think I'm going to use a 98-02 F-body pan since I can get a trap door baffle that bolts in. http://www.improvedracing.com/oil-pa...ffle-p-30.html Quote:
I thought they were neat too. Two bolts and the engine is out. I found another similar kit that I liked but it didn't have the option to move the tabs around, and the outer tube of the bushing welded to the tabs. The ones I ordered have only a bolt going through the tabs and the outer bushing tube is removable. This was the other similar kit- outer tube welds to engine plate and isn't removable. Both are compact and simple, I didn't really like the ones with a huge rubber/urethane mount with brackets and plates everywhere. The bigger ones probably dampen engine vibration better but I'm not old enough to worry about that yet.
12-26-2012, 02:12 PM | #7 |
Hope everyone had a very Merry Christmas!! The engine mounts came today and they were better than I expected them to be! Thick 1/4" plate for the plate and tabs and the edges were scalloped for weight reduction too. Nice grade 8 hardware and the steel sleeve for the bushings fit tight around the bolt. The holes in the tabs for the mounting bolt is a tight fit too- no play at all. Very nice kit!
